Hi guys. A few of you have suggested to just take off my thermostat if I am running an oil cooler.
I have a massive oil cooler now so it's all good. Ever since owning the car (1 year now) I have noticed that the car takes absolutely forever to warm up. It's nearly impossible to sit there and wait for it to warm up. I can get quite far driving it easy and shifting before 3,000rpm before it actually does warm up!
Is this a buggered thermostat? Can you really just take it off? OR Should I be buying a replacement one, or even a Nismo race thermostat? (don;t know much about those but have seen them in the mags).
Any help appreciated (as always!).
https://www.sau.com.au/forums/topic/61930-thermostat-do-i-need-one-or-not/
Probably yours is stuck open. My gfs corolla took a long time to warm up and on the highway temp would fluctuate a lot. Took the old one out and it was visibly open. The car now sits on 1/2 on temp gauge all the time.
Other things it could be is temp sending unit, but thermostat is $20 so good place to start. Take the old one out and compare its function with a new. Put it in a cup and add boiling water. If it is the same as the new one then take the new one back. They usually come in plastic that can be resealed. Also get a seal with it. Autopro I think has these. Tridon is the brand.
I dont see why oil cooler would effect whether you need a thermostat or not.
Yeah genuine Nissan 76.5degC thermostat is what you want.
About $35 from Nissan Spares.
Alot of aftermarket ones i've seen are a bad design, and can get stuck open due to their design.
You want your car up to temp as soon as possible, to avoid engine wear and excessive fuel consumption.
umm I think you guys are talking about 2 different thermostats
1) is for water and is inthe block, that is where you can buy the uprated ones like 76o
2) is for oil cooler, it won't circulate oil to the cooler unless it needs to. this is what you need for the engine to warm up properly. We don't run one but its a race car so warm up and idle is not an issue.
Sorry, i thought we were talking about water side of things.
If its a road car, with a big oil cooler, then yes get a thermostat for that (for the oil cooler), as it will have the same side effects as the water thermostat will on motor operation.
Cheers
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
