Hey all,
Quick question that's been bugging me for a while. I get a sudden drop off of power under light throttle. Can happen in any gear, mostly in 5th gear when accelerating lightly from 100+km/h and backing off the throttle slowly.
Now I know this is due to the fact that the boost is dropping off sharply, but I can't pinpoint why. I've tried adjusting my BOV and it didn't seem to make a difference and it's really starting to bug me.
Ideas? Comments? Help?
https://www.sau.com.au/forums/topic/61944-surging-under-light-throttle/
I have the same problem with my car expect the surging happens when I am at a constant throttle trying to hold a fixed speed. I have an FPC and I turned off the O2 control and the problem goes away. But my gas milage suffers. I guess in my case a new O2 sensor may fix the problem.
I don't think it's anything to do with fuel regs or O2 sensors as I have no other problems with the car.
Boost controller - not sure about this one. I run a HKS EVC4 and it works a treat. Haven't had any problems with it getting the set amount of boost happening..
boo5t - I tend to agree that it's a BOV problem.. just not sure how to fix it.. perhaps SK has an answer? He usually does.. :rant:
Hey all,
wot ecu you using is it std?
this is definity o2 sensor (not like the problem descrided in this thread) as you hold fixed throddle position the ecu switches from map to closed loop control on the fuel system and with the pfc as you have done you can disable this closed loop function and uses the map only with cause the heavy fuel use , so buy new o2 and save some $$ on fuel. :rant:
Piggy Backs? well what my thinking was , was basically tune around light throddle was out or out because other facts. As most dyno tunes will not even look at parts of tune off the std power pull path (ie light throddle etc).
my surgestion would be most like check all or analog input (throddle sensor,o2 sensors etc)
and if no luck buy apex pfc and get a good tune to ozzy condition and fuel.
sorry cant be of more help.
  • 2 years later...
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
