Can any of u guys point me towards a good polish to get rid of small chips etc in the car. I don't really want to use a cut and polish too often, how often do you reccommend using a polish.
i use glide on glaze to get a good shine after a wash, but it doesn't get scratches etc out, it is just for shine :) Shine is good :)
https://www.sau.com.au/forums/topic/6197-polish/
use meguiars paint cleaner if u want to take off very very light scratch or marks from the paint. or stains, swirls etc. paint cleaner is good stuff. else use meguiars scratch X, i haven't had the need to use that, but i heard it works pretty well. like a lite cut n polish. i wouldn't use any of this stuff too often. i only use paint cleaner like once every few months.
https://www.sau.com.au/forums/topic/6197-polish/#findComment-93422
Originally posted by MRK25T
What can you use to get out small scratches in a double din head unit to make it look like new again?
Mark
I used toothpaste.. yes, toothpaste! (non-gel kind of course!) It's almost like a VERY fine cream cleanser...
use at own risk tho... i used AIM btw ;)
https://www.sau.com.au/forums/topic/6197-polish/#findComment-93844
Amongst my collection of cleaners and polishes are the following, hopefully this will help you guys
1. Autoglym Super Resin Polish (remove marks and small swirls)
2. Autoglym Glass polish (marks on glass, yes i use on headunit)
3. Meguiars hi tech yellow wax (use after polishing)
4. Meguiars Gold Class Wash (the only wash to use)
5. Meguiars Chamois
6. Meguiars cloth and trim cleaner (EXCELLENT STUFF)
7. Windex
https://www.sau.com.au/forums/topic/6197-polish/#findComment-94358
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
