Gday!
I've got a Greddy Profec B Spec II boost controller on the way (with english manual and all the gear to install it) and i have a couple of questions hopefully a few technically minded ppl can help me out with. For everyones info i have an RB20DET powered R32 gtst with the following mods:
- cat back 3" exhaust
- pod type air filter
- apexi power fc
- bleed valve type boost controller (boost now up to 11 - 12psi)
My questions:
1 - I generally know my way round a car but are these things difficult to install?
2 - Would it be advisable to have these fitted by a pro? If so, I'm in Chatswood, Sydney - anywhere someone can recommend?
3 - Is this model fully electronic ie can it limit boost to certain point and prevent boost spikes?
Thanks to anyone who replies...Cheers :mad:
Gday!
My questions:
1 - not really . plum the solonoid in where your old boost cotroller was and then run a vacum line hose from the manifold . There is a article in the DIY section on installing a boost guage on a r32 , same principal applies for that . then run your hose and cable for the solinoid back into the cabin and mount the controller
2 - its up to you . if you feel confident give it a go , if not its probably about $100 to get it installed . those profecs are pretty strait forward
3 - yes fully electronic , it will be more stable than your bleed
Installation should be straightforward but apparently Profec B II is fairly hard to set up. Probably best to leave it to the pro.
Saying that, I just bought Profec S that is like the old Profec B, brought back due to popular demand, just with an improved solenoid. It's much easier to set it up but it doesn't have the fancy screen.
yeah figured there'd be a few steps in the install which'd be beyond me...can these be done by any auto electrician or are dedicated performance tuners the way to go?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
