1994 NISSAN SKYLINE ECR33 GTS-T
Price $17,999
Kilometres 82,000
Body 2 door Coupe
Colour Black
Interior Colour Black Charcoal
Transmission 5 speed Manual
Engine 6 cylinder Petrol Turbo 2.5L (2498cc)
Excellent condition with extras, Pioneer CD player, Apexi AVC-R Boost Controller, HKS Air Filter, Lowered RSR Springs, Full 3" Exhaust System, Near New Tyres, Genuine Skyline Floor Mats (Front & Rear). Some Spares included ie. Timing Belt + Drive Belts.
It sounds awesome and I have some pictures below Im just wondering what the general feedback is on this car before I spend the cash..
I will offer about $16999 for it as its a 1994 model.
Anyone think its a good buy?
https://www.sau.com.au/forums/topic/62029-can-i-get-some-opinions-on-this-gtst/
Hmmmm sounds ok.
Even though the RAC aren't the best at checking over cars maybe get a check from them or even better take it to more a reputable mechanic such as Hyperdrive or SST. Give them a call and see if they do inspections for you such as compression tests onthe engine.
I think for the couple of hundred you may spend it would be better than blowing thousands..... for piece of mind.
Other than that get some mags on it and all would be schweeet!!
Just spoke to Ken at Hyperdrive and man was he a big help!!!!
That guy knows his Skylines big time..
A check over on the car.. "a very good check over from what I heard" will cost me only $160, money well worth spending if you ask me.
ThanX 25GTT
:rofl:
looks damn good, makes me pissed that i bought my 95 SII for 20K 1 year ago and this one here looks superior and only 82,000 kms.
One thing though lots of sellers are very reluctant to take their car to someone like SST or Hyperdrive cause anything that pops up makes it look so bad for the seller.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
