yea one of the guys i work with got a call from his gf in woden who said they just got hit by HUGE hailstones. looked at bom.gov.au noticed another one heading towards the city. Luckily moved the car to the tradies :mad: walked back only spitting at this stage and by the time i got up the lift and to my office i looked at side and it was PISSING DOWN 2 minutes later heaps of hail the car park started turning white :mad: all i can say is i am glad i moved my car
That was pretty full on !! I was down in Gordon visiting when it started. Pulled onto Drakeford Drive and I could actually see the wave of hail stones coming up the road !!
I just gunned it to my place and got the car under cover.
Then after that one had passed we got another hail storm that was bigger !! Damn that lightning got close too !
J
Tuggers out Condor way was pretty well hit. I was on the phone to Shane about 12:40 and heard it startup in the background. He reckons it was plummeting down within moments. Manged to get a word out to Ed n Jayce, both being in the vicinity.
Didn't seem too bad here in Dickson
wtf i am in transact building in dickson and at one stage its was pretty damn heavy a guy brought back a couple of hail stones about the width of gold balls but half the heigh i would call that pretty big :rofl:
Sure it wasnt Ice Cubes for the Scotch, and wot colour were they...lol
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
