yeah i know where it runs RV i think they probably wanted to do what you said, ok so i'll tell them to simply replace the ruptured section for me and if they say no then.... well.... i'll deal with no power steering cos i ain't paying that much!
nebuchmeizzer: i've read the entire ECU can just go "kerplunk" if they haven't been looked after too well and high mileage, n i doubt you'd really be too inclined to find yourself stranded on the side of the road somewhere with a car that's gonna cost thousands to fix, also, as far as "cosmetic" electrics go you have proto-type 80's technology and you KNOW nothing good EVER came out of the 80's technology wise...
IE: hicas, automatic lights that turn on for you, power windows, central locking, etc etc etc... not trying to scare you or anything but it's best to look at things realistically other than optimistically =)
only problem i've had with my one is the power steering hose, other than that GREAT car, ABLSOLUTELY FANTASTIC, if you have the money though (making the assumtion you're a mechanic) i would buy a virgin stock one and build it up from there that way you don't have to maintain + mod, knaww meeen?
Ya mechanical and electronic stuff i can fix, electronics is a bitch but i can fix it eventually haha. Modding is all good to, the car in my sig down there was 90% built by me and 10% by my dad.
I might be holding off on the ceffie for a bit now, the old gazelle had a good showing at State Drift last weekend so i might do a little more playing with the rear suspension and see what it can do before i upgrade, that is unless someone comes along and offers good cash for the old girl but that's unlikely.
The gazelle stands out alot at meets which is good :P
Is the power steering interchangeable with other Nissans?
R32? S13?
I mean the whole lot - pump, column, everything..
i would say similiar if not the same to an s13 ......? im not fully sure though
but i recently did the steering wheel and the boss kit for the r32 did not hook up proprly ...but the jap s13 one did ...
replaced my old man's ceffy's steering wheel with an R32 steering wheel. works fine. good thing we don't have HICAS in the ceffy, which is what you'd want in a drift car anywyas...
The only problems I've had with mine was a crack in the fan (so the fan got replaced) and holes in the exhaust (so the exhaust got replaced). There was a minor oil leak somewhere due to bad washers, which were replaced and all is good now.
is this cefiro boss kit?
matches up with S13?
the r32 one fits the spline but it had nothing to turn off the indicators or activate the horn ....the kit for the australian nissan didint fit cause the spline is too large .
i finally got one which was made in italy for it, i think for the s13 but i could be wrong ....but it fit and everything hooks up fine indicators turn off and horn works i had to add a little bit of wire for the horn but ohwell it works
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
