hey,
I have an 1993 R32 GTST and just blew a box. I have heard that rb20 boxes arnt much good and to go for an rb25 box. I have heard its a bit dearer and harder to do but is it worth it? has anyone else done this transfer and had good results? My car makes 345rwhp so it has to handle that,
thanks
https://www.sau.com.au/forums/topic/62117-skyline-gearbox-trouble/
hey,
thanks
Hey man,
I have also gone through a couple of RB20 boxes. The fact is, you only have to go through 2 Rb20 boxes to equate to the cost of an Rb25 box. If you can afford it, putting the RB25 box in is the go - just make sure you find someone that knows exactly what they have to do. When i was making enquiries about rb25 box in my r32, i found myself having to tell the mechanics what to do rather than them telling me what they had to do... which scared me.
Good Luck with it man.
thanks,
i have a guy who I kinda know that put a rb25 in his 32. He seems to know what he is talking about so I think that mite be the way to go. I have a 5 puck sprung os giken extreme clutch so it would be a bit nasty on the box too. Apparently you have to shorten your tailshaft and change the speedo gear so the speedo reads rite? dunno, stupid gearbox.
i have 270rwk and my rb20 box is alive and fine
i have the same and the box has ben geting a bigger whine each week.
Not its so loud you'd think the car was supercharged.
Its taken a fair amount of punishment though i must admit.
Get a 25 box, its not a great effort to put it in, as aKTiVE said... go through 2 RB20 boxes and you'd done the cost of a 25'er
its not an os giken its an exedy extreme clutch matt..... taking that clutch out is not an option... it shat a brand new heavy duty organic after 5 runs on the dyno this clutch is the only one thats been able to hack the power in an off the shelf clutch....
ive advised matt to find anoter cheap rb20 box to get him rolling again and to start taking it a little easier on the 20 box till he can afford to have all the bits to do the 25 conversion in one hit rather than taking 2 months to get all the bits together while the car is off the road.... he has only had it for 2 weeks all up so far..... hes just gotta get over the "i have a new car that spins the wheels whenever i want it to SIK BRO!!!" period
haha
and yeah incase anyone is wondering yeah its my old 32 gtst :)
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
