Hi all ... I have an Apex AX53B70 Turbo kit for sale ... it has been on my car for ~5000kms. No play, turbo is like brand new still and has always had the water lines connected and also had only good oil in the engine. Turbo is a great respone turbo and is rated for 380ps.
You get:
-AX53B70 380hp Turbo
-Stainless Exhaust Manifold - I think it is an Apex manifold (Heat Wrapped - no cracks)
-Stainless Dump Pipe
-All Braided Lines (Oil & Water)
-Silicon Joint (from Turbo to top piece)
-Cool Apex piece of piping from turbo to your standard cooler piping.
The kit is a direct BOLT UP to your RB25.
I am asking $3500 for the kit ... I have photos now - please see below
My power rating is unknown due to a sh**ty tune and not completing the car to get it actually Dyno run ... the turbo is still on my car and is boosting fine ... if anyone is interested however, and payment is made ... the turbo will come off in 1 night and sent the next day ...
Please PM me for more details if you are interested - no time wasters. Thanks guys ...
What model? Without looking it up there is the P21, P22 etc etc. It refers to the exhaust housing size, from memory its the A/R but in mm where Garrett state the A/R in inches. (Eg Garrett 0.87 is in Apexi IHI terms a P22)
Interested if the exhaust housing isnt on the large side...info to tbrisby@yahoo.com when you can:)
Um, that's actually a good question ... There is no marking on the actual Turbo itself ... I'll have another look and get back to you ...
Pics sent to both requests ...
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
