heya,
this may be a dumb question but,
las nite was the firstd time i took my r33 for a decent trip. now when highway driving my HICAS light came on and wouldnt go out until i had turned the car off and started again. is this surposed to happen? if so what the heck does it mean?
cheers!
matty
https://www.sau.com.au/forums/topic/62126-hicas-light-turning-on/
thanks dude!
I will take a closer look but I have a funny feeling it isnt there....the car is still getting the aircon sorted out... Im sure I am going to get murdered for the 134 conversion and the second hand compressor.... :)
could it be somewhere else? its 11/92 R32 GTR......
I never really noticed or felt the ATTESA working on mine. My bro thinks its what makes it squirm around in the wet when driving over standing water, but I keep telling him that its aquaplaning cause the rear tyres are too worn :roll:
Well they didn't find the prolem today, they did work out that it comes on after about 4km of driving. But they couldn't get the HICAS ECU to do a diagnostic check, so it might be the ECU. It's going back in, in acouple of weeks, and it'll stay there till it's fixed this time.
4 wheel steer @ high speed and only up to 1.4 degrees i believe
Nope, not just high speeds. While parked, get a mate to yank your cars steering wheel to full lock (left or right) and watch the back wheels.
Jordan: You wouldn't experience ATTESA unless you own a GT-R or GTS-4. :D
sav man: have you tried getting in to HICAS diagnostic mode yourself? Its not all that hard: instructions are in the FAQ forum. Actual understanding the codes is a bit difficult though :rofl:
LW.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
