Hi,
I found this timing belt, it seems like a good price, is the performance any good?
Engine code Type; RB20DE, RB20DET, RB25DE, RB25DET, RB26DETT 1985+
Suited for Models: Nissan Skyline
Manufacturer: Gates Australia
HOR Part #: GT1040R
Photo may differ from actual product
GATES RACING TIMING BELTS
Specially designed high performance timing belt for racing and performance tuning applications. Higher capacity than standard timing belts to give piece of mind for performance engines. Racing timing belts are identified with a blue coloured cover material.
Design Targets
? High strength glass tensile cord
? Heat resistant elastomers with higher crack resistance
? Specially modified jacket material providing increased tooth strength
http://hioctaneracing.com.au/eshop/product...products_id=439
https://www.sau.com.au/forums/topic/62131-timing-belt-good/
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
