1997 S14a 200sx
Riveria Blue (Factory)
107,XXXkm's
5 speed
SR20DET
Tinted windows
Optionhouse Front mount cooler (700mmx400mmx60mm)
K&N POD filter with custom piping
bleed valve running 9 - 13psi
walbro 255lph fuel pump
3"inch mandrel , frontpipe back
highflow cat
supercat muffler
lowered on king springs
Stock 16" rims with low profile tyres (Rear are 2 weeks old)
Autometer boost gauge
Apexi Pen style Turbo Timer
JVC MP3 Head unit
SONY 6x9 Rears
Dyno'd with 157.9 rwkw's (dyno sheet to prove)
Rego until *DEC '05*!!
Serviced regulary, very clean and well maintained car
I even have the Nissan service books dating back to the time of purchase
Have all receipts also!
Overall very clean and tidy, sounds horn with huge flutter!
$19,000 neg! open to offers
NO RWC
Very Genuine sale, going overseas in a few weeks, MUST GO!
No time wasters, serious buyers only
no test pilots unless deposit is shown! (very busy next few weeks)
Phone or SMS 0403007119 or [email protected]
more detailed pics up soon!
https://www.sau.com.au/forums/topic/62134-fs-1997-s14a-200sx-melb/
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
