  • 3 weeks later...
  • Replies 52
most people already know my car, white, 77k, t78 set up, power fc, trust intercooler, 720cc injectors, aftermarke suspension, veilside andrew wheels, 18x10fronts 18x11rear, full ROLL cage, trust oil cooler kit,adjustable cam gears, tomei lumpy cams, oil filter relocation kit, z32 afm with hks pods, custom mount for oil pressure, boost, and ext temp gauges, turbosmart Eboost contoler , 5in monster tacho supplied, carbon fibre bonnet, v-spec front bar, custom plates JETT, comes with full nitrous wet kit, with brackets & bottle warmer, bosch 044 fuel pump, modified gearbox, os giken twin plate clutch, momo millenium steering wheel and gearnob, made 450alkw with 20psi and 50shot of gas, and currently is in position 10 for fastest 4wd above2.4l on www.hpi.com.au running 10.815  ( also supplied is a full set of slicks for the track)
looking to see what i could get for the car befor i decide to rebuild it for drag race only.
if anyones interested 0425239844 where any questions can be answered.
PRICE $48,000.00 ( $1000 discount for SAU members which will be donated to the forum)
When you ran a 10.8, how much power did you have at all 4 wheels and at what boost?
  • 3 weeks later...
come on guys, for all the people looking to buy a stock r32 gtr for 30k+ here is a perfect example of one mans loss is another mans gain. No need to spend any money on mods, everything is done and the car is ready for racing or just as a daily driver. 39K is cheap. must be someone with some money not every can be broke at the same time.
  • 1 month later...
  • 4 months later...
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
