Just tried to start it and was trying to turn but didn't have enough charge. Changed the battery and she started crankin.....but not firing. Air, fuel and spark. The fuel is right, as there is pressure and I've changed the fuel inlet and fuel return pipes over to no avail. Air is right as there is nothing blocking the inlet piping and I've tried starting it with full throttle. I'm thinking either fuel injector's or spark plug's/coil's. I got it started when it was sitting in the halfcut so I don't think the actual injector's, plug's or coil's are faulty but perhaps I've missed a ground wire or even a positive wire for it. What are the critical wires to connect for the fuel injectors and/or the spark plug's. Are there any unusual grounds that anyone knows of that I might've looked over?
Any help appreciated.
BTW - It is an r32 rb20det
What are the standard ways of checking that the injectors and spark plugs are getting charge without having to access the coil's?
https://www.sau.com.au/forums/topic/6219-first-crank-of-new-engine/
You haven't disconnected the CAS? Igniter pack is connected OK? Igniter pack has an earth - its connected? Cams are in the right position?, particulary the exhaust, since it controls the positioning of the CAS.
Take the CAS out (keep it connected to the loom), take note of its position so you can put it back in the same spot. Put the key to "ON", slowly spin the CAS shaft (anti-clockwise) - you should be able to hear the coils firing.
Crank the engine - you should be able to hear the injectors firing. Use a BIG screwdriver as a stethoscope if necessary.
Maybe you can run a diagnostic from the ECU - presuming you are running factory ECU?
BTW, did you spin the engine over and get oil pressure b4 you tried to actually start it?
blind_elk,
I established that the injector's are firing so it is the spark.
I haven't disconnected the CAS, I got it started in the halfcut and haven't altered it since. If by igniter pack, u mean the power transistor, I don't know if it is ok but I'm assuming it is as it worked before and all connections are in it. The earth wire which is black with silver dots and goes onto a screw on the igniter pack is connected. Cams haven't been touched. If I do what you said with the CAS, if it does fire, what does this tell me? and vice versa, if it doesn't fire, what does this tell me?
I've run a diag from the stock ecu and it is all clear.
And no, I didn't spin the engine over and get oil pressure before I went to start it.
Any ideas?
Its a good idea to make sure you can get oil pressure before you actually start a new engine - don't want to run those nice new bearings without any lubrication, now, do we?
OK, back to the problem at hand. Pull all the coil packs, stick a spark plug in each, and crank the engine - see if each plug is sparking. If it sparking, then its obviously somewhere else. Maybe pull all the injectors and check that they spray fuel while you crank the engine.
Meanwhile, I'll check out the manual tonight and get a list of "My engine won't start" solutions.
1. Check fuel pump is working (during cranking).
Should be able to feel the fuel line pulsating during cranking.
2. Injector can be heard during cranking.
3. Ignition
a) tacho needle flickers during cranking?
B) hook up a timing light and check flashes during cranking.
c) as I suggested previously, pull a coil pack and insert a plug, check if it actually sparks.
After that, FIIK.
Yep, fuel pump is definantly working. I can hear it and the fuel lines are pulsating. My tacho isn't connected so I can't read off that. Where abouts do I connect the timing light?
And it's a bastard to rip out my coil's and spark plug's out of an rb engine compared to my old ca!
There should be a loop of wire near the igniter. A conventional timing light will work off that (may not be accurate, but will at least give a signal).
I know its a bastard, but you want the engine to start, don't you? You have to do stuff to track down where the problem is.
You're absolutely sure the fuel lines are connected the right way round. Disconnect the return line and check if fuel comes out when the pump is working.
  • 3 weeks later...
Just as a final post, I found the problem a while back.
I connected the white/purple wire from the ignition relay (on the rb20det engine loom - little green box) to a blue/red wire (I think) going into the fusebox that connects to the 30amp ignition fuse as per the wiring diagram.
Also, I had connected pin 16 (eccs relay) to the eccs relay on the silvia engine bay loom but I had to also have it connected to the orange wires coming out of the skyline engine loom ignition and eccs relay's. And she started!!! much to the delight of me. Originally I didn't have the ignition and eccs relay's on the skyline engine loom connected because I had connected the wires to the corresponding wires on the silvia engine bay loom and assumed that there were the corresponding relay's in the fusebox.
Thanks to everyone that helped especially blind_elk. Thanks mate.
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
