PM sent to all but just advising any new comers that I have sold them to MR rx-[7]. Not only that but will be going to JAPAN soon and mite be getting more if any requests are made. With any other performance parts please dont hesitate to make a request and I'll get back to you with prices ASAP. Please email me on [email protected] for any requests.
