i am into r31s obviously. so call me biased.
but i can't go past the rb30e.
mine has only bout 205. i have absolutely abused the car since i bought it at 136,000. that was 2 years ago. it has sat on rev limiter for a total of about 2 hours at a motorkhana day. it's done 4.5 minute burnout in 1st gear at 6,200 in burnout pit at wsid. various others engine harming experiences where it just bounces right back.
i'm not known for engine maintenance, but car does not miss a beat
the rb30e is amazing
we know of a guy with a 31 that was done 700,000. no kiddin.
anyway i'd go so far as to say it's definitely the best engine in this country ever, if not the world.
  • Replies 51
I can easily top that, I've an old VL toilet door thats done 1,600,000 K's on the same donk. I've gone thru 4 heads, but the donk & tranny (auto) are factory original. I bought the thing new, & it hasn't missed a beat since 1986. Thats why i've just bought an r32 gtr, which has just blown the @@##?? clutch.....
I forgot to add that the speedo shit itself at 1.5,-0000000 (is that enough zeros??) but why bother to replace it. I've currently got the car for sale but i dunno whether to tell any prospective buyers that the speedo reading is second time round ????? :Bang:
  • 1 month later...
my rb20det had approx 180,000ish just before it died, not actually sure of what happened, motor blew the day it was sold.
The day it waz sold... Thats lucky....
was it out of your hands after the engine died?
I can shed some light on it since i bought the thing, it was out of his hands and in to mine when it let go, but i knew it was f@rked and paid accordingly.
Ben you need to have stern words with who ever touched your cam belt last, it'd been put back on a whole 2 teeth out, and the chance of it jumping teeth by itself is slim. Once that was rectified it actually compression tested up reasonably well but it'd done a big end bearing on #1 cylinder so we just ripped out the engine and replaced it (60-80K engine but who knows with wreckers?).
If you're interested mate your old beast now has nice FMIC and Electronic Boost Controller only pushing 12psi but will wind it up some on the dyno next month. So far its been good to me and did Melb - Adel trip no worries.
Good luck with your Ceffy mate.
Hmm very interesting Ash. I will have to ask a few questions with that workshop ;) Don't think i will be taking the ceffy back to the same place, espec considering it will be up for a new cam belt when it gets here. Having the timing belt teeth out didn't cross my mind. And yeah i had actually tested the compression a few months before the problems started and amazingly did have a pretty even compression in all cylinders.
Otherwise it Great to hear the car is now going well!! ;) If your still using the same ECU you should be able to find someone in adelaide to do a new map for the FMIC, otherwise i'm sure sam(dr drift) will send u in the right direction.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
