Jerry, how are you going for stock on these? I am getting sick and tired of recharging the battery in my car, so I wouldn't mind getting one shortly.
I don't have any but I can get them at any time as long as I get 5 to get them at $140 . If anyone else wants any I only need a couple of days to get them in .
West , if you have any problems finding posts, I can them for you here for about $18 for the 2 including the screws. Don't hold me on the price as its a long time ago .
  • Replies 376
Posted Images
  • 1 month later...
  • 4 weeks later...
what she said^^^^
if they are available still pls pm me, it is time for me to replace my battery.
thanks
O.K guys looks like there are a few of you that may want batteries .
I can get these at anytime as long as I order 5 at the time. All of you that want one please post here or P.M and I'll see what I can do for you. Price is still the same $140 pick up in Sydney ( or even meet up somewhere). For interstaters extra $20 for post in the eastern states and S.A. , W.A. and N.T. around $40 .
interested in buying one when you order next. i am located in sydney. can you still supply posts as well?
If you need posts, I should be able to get you some as long as you don't want the small posts that most Skylines have .
hey mate,
interested in a battery, but anyone from melb got one?
i'm interested to know where i can get terminals and the clamp?
would they fit a 180sx engine bay?
cheers
I'm sure you can fit it in the engine bay but I'm not sure what you need to mod to fit it. The battery is about the same length and height as your stocker but a little wider ( about 5 cm wider). You dont need terminals you can use eyelets and bolt them on the battery with the s/steel screws that come with it . If you want you can fit brass posts on the battery but I can only get the standard (bigger posts), if you use them then you have to change your terminals to the standard size, most Nissans have the smaller ones .
If you are keen I can send it to Melbourne, post will cost you $20 including rego and insurance .
  • 1 month later...
Has anyone squeezed one (or two) of these behind the trim in the boot on the right hand side of the car ? (as in where the jack sits but on the other side of the car) in an R33 Gts-t
I have seen people move the battery from under the rear parcel shelf into here, and I was wanting to put a second battery in as well in the gap and move the trim out a bit.
Cheers
Heath
  • 4 weeks later...
Just want to say that these sealed batteries are great.
I picked up one of these batteries from Jerry about a week ago as my old one one kept going flat after a week.
Installation was a simple enough process - just remove old battery and put new battery in its place and connect terminals by turning clamps sideways and screwing them down to battery terminals with the bolts supplied with battery.
There's no real need to purchase any battery posts or clamps. I just had to purchase a longer (7 inch) bracket to hold the bigger battery down ($4 from Repco).
I also cut a small sheet of rubber foam and placed it underneath the battery to stop any chance of the battery moving around as the original battery tray is not big enough to hold this battery.
Just about the only problem i had with the installation was that my rear strut brace had to be removed temporarily until i had installed the bigger battery as it could not slide through the gap like the old smaller battery had.
All in all i'm very happy with the new battery - Thanks Jerry. :worship:
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
