Have a look in the thread mate and you will see how others have installed it .
It will fit in the same place your battery is now but because its a bigger ( wider ) battery you need a new 7" braket ( your car has a 5" bracket) and you need to discard your battery tray .
I have one in my R34 GTR but to take a pic I have to strip the car boot .
Cheers , Jerry
my battery is located in the engine bay its a four door and what i wont to know is how do i connect the power and earth because the connections are not like your normal batteries
thank you
  • Replies 376
Posted Images
thank you
You have two options.
Buy 2 brass posts ( they screw on the battery) or convert your Positive to an eye , the Neg should have an eye.
  • 5 weeks later...
  • 4 weeks later...
So many pages to read, here's my questions, how much are they now, will it fit in my r32 gtr battery palce without probs, and what will postage be like to SA?
Mine arrived yesterday, required alittle bit of creativity to attach my grounding kit to it but it's all good (R32 GTR enginebay mount), never seen my car start on the first turn before.
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem
Thanks
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
