  • Replies 376
Posted Images
I still dont recomend it for any car , i have a smaller one that i use on my jetski and it will start a car no worries . Its 2 years old now and still works very well on the ski , if it was in car though i would have problems .
Why do you want a very small battery ? space ? if yes move it to the boot of the car , thats another advantage of the sealed battery.
I was told that even sealed batteries are now illegal. VicRoads or RTA wants to see a normal battery with a breather hose going into the boot floor and outside the car. As per stock original R33 battery.
Not trying to rain on anyone's parade, if anyone can confirm this it'll be good. If sealed are a no no with RTA/Vicroads, better be careful if you're trying to go through a RWC process to get a car registered.
PS My battery getting weak and I found a Denso battery replacement (unsealed) with a breather hose just like the stock R33 skyline, through a compliancer in VIC. I got them at trade price. A bit higher than original so you'll need to tilt it sideways to connect the negatives first, then tilt it the other way to fit the positives, then once it's flat you can secure it with the stock bracket.
Who told you that sealed batteries are not legal to have in the boot ?
Sealed batteries have many advantages over normal lead acid batteries and only one disadvantage - price .
An auto electrician near my place... when I was looking for a replacement without luck... As I said in my post if anyone can confirm this info correct or wrong that will be great.
i didnt read much of the replies except the inital posting but would like to know if these batteries are small enough to fit into a small enclosure. I have a tight engine bay and want a powerful battery but quite small.
If you scroll down you will find the pic and the dimentions . They are 20x17x17 cm
  • 4 weeks later...
hey Jerry....
side note that I added a circuit breaker to the system on the install! but out smarted my self by only having 100amp switch!
so to anyone doing this, I bought all the gear from JAYCAR and now would recommend the 150amp switch (I will be getting that one now!!!)
4 guage wire and a mounting kit from supercheap!
GREAT BATTERY!!!!
oh and I love my GT-SS's
as jeremy clarkson would say....."ohhhh my!!!!!...... my dear!"
Any of these left?
Whats the exact dimensions of the battery??
No left but i can get them for $140 each as long as i have 5 orders .
go to post 17 in this thread for the dimentions and on earlier post you will find a pic .
Great 1.2 bar @3800 rpm in high gears , i'm going to wsid on the 29th .
1.6 bar on an old stock engine ? are you crazy ? I'm happy with 1.2 bar for mine .
What type of clutch are you going for ?
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
