Hey guys,
Can you have a look a these photos for me?
Looks like it might not be a hig flow cat but i would have no idea.
The rest is 3 inch as in front/dump and cat back.
So if this isn't, i would like to get rid of the bottle neck.
Will i notice much difference?
Should be able to get one off ebay for $160 i hope.
Yibeda yibeda !
https://www.sau.com.au/forums/topic/62270-high-flow-cat-converter/
Hi Birnie
Doesn't look like it, but very hgard to tell from the outside!! take it off and whild looking through it, hold it up to the light, if you can see the light throgh the mesh, then it may be a high flow. I put a magnaflow in mine and they usually retail for ~ $400, I got it through a mate in the trade for $150.
I'd be careful of the $160 'high flow' cats - if the are the generic type, forget it! save the money and get one that has actual flow figures provided for it.
On the issue of liberating a few ponies, when I imported my car it had a full 3.5 inch system, no cat or mufflers, this is the only way to improve exhaust flow - but not legal :cheers:
noticed a drop in performance when I fitted the legal system - also slower to come onto boost.
Hey guys,
Yibeda yibeda !
get in contact with BATMBL on the forums here, i got mine off him a while ago, cant remember how much, but was cheaper than anyone else
i got one (including front/dump) for my 34 from BATMBL. Have fitted or driven the car yet :P but how'd you find the car after fitting the new cat?
cheers.
cheers.
i fitted his 3" front/dump also,
already had a 3" catback
it does the job, i dont really see the differences in all these cats, they all 3"
some are larger voloume. thats all
why pay $500 for 1kw difference?
A friend has a ballistic s/charged rodeo ute and has upgraded to some magic cats ( twin exhaust).
They are not fitted yet but the workshop is going to do a before and after with the old high flows first and then whack on the magic cats to see if they are all they are cracked up to be.
I will post results when its done.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
