Guest GR33DyMANGO
once the turbo timers on.. couldnt someone get in the car (ie break window etc) then once inside just keep pushing the turbo timer button to the longest amount of time then just keep pushing it??? someone could potentially keep driving until they reach their garage where they strip your car etc....
im sure it happened to my friend as a joke... but his was just driven round the corner.
hehe yeh good point but u can disable that with a screwdriver and a bit of effort.
Remember the simpsons ep where Mr Burns gives Bart the ferrari and he cant even see over the wheel. ahh i loved that ep:lol:
  • 2 years later...
with my car being an auto u cant get the keys out of the ignition unless its in park and cant change gears without the keys being in the ignition. hell u cant go into reverse unless u put ure foot onto the brake.....
but even still if the people can find ure TT then they have direct acces to ure ignition wires and can just satart it coz most immobilizers dont activate till 30 secs after the car stops, unless u have ure alarm wired in to allow it....
Bambam when you say they "searched" your car what exactly did they do and where did they look?:eek1:
Searching Persons without a Warrant
The Police Powers and Responsibilities Act permits police officers to search persons without a warrant.
The authority of the police to search a person without a warrant is dependent upon the existence of a ‘prescribed circumstance’. If a police officer reasonably suspects that a ‘prescribed circumstance’ exists. The prescribed circumstances in which an officer may search a person without a warrant includes circumstances in which the person is reasonably suspected to be in possession of:
a weapon, knife or explosive;
an item which the person intends to use to cause harm to any person;
a dangerous drug;
stolen, illegally obtained or tainted property;
evidence of the commission of an offence punishable by a minimum of seven (7) years imprisonment, which the police officer reasonably suspects may be concealed or destroyed if a search is not conducted;
an implement of housebreaking, motor vehicle theft or drug use.
Searching Vehicles without a Warrant
An identical set of rules apply to police searches of vehicles without a search warrant. A police officer may stop and search a vehicle, together with anything in it, if any of the above ‘prescribed circumstances’ exist.
When searching a vehicle, the police are allowed to enter, re-enter and stay in the vehicle as often, and for as long, as is necessary to properly carry out their search. The police also have the power to move a vehicle to an appropriate place for a search, in particular if it is impracticable to search the vehicle where stopped.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
