Does anyone know where you can buy a drivers side and passenger side boot kit?
My outer passenger and inner driver side have both started to crack damn it!
Any help appreciated.
thanks
:headspin:
any decent drive shaft place should have the boots, I got mine for my GTS4 in Brisbane from the Australian CV joint centre - about 2 years~ ago they supplied and fitted the boots(inner & outers) to the driveshafts - I took into them for about $70. The driveshaft nut that holds hub is VERY tight and I had to hire a huge socket set so I could get the bugger loose.
I dont know about any 'kits' - if you mean one where the driveshaft doesnt need to be removed, like the steering rack boot kits that you can get.
Check the specs of the grease they use against what nissan recommends in the workshop manual to make sure it is high grade enough, it will probably be better than what was available in 1990~s but check while you're at it. You will have to put grease in one side yourself and fit one boot to diff, the other side just bolts up.
Stephen
You can get them from Nissan but they are about $70 each .
Go to any auto shop and get a universal boot kit , about $12 -15 each , they have the molly grease with the kit . You dont have to remove the driveshafts from the car to replace them .
thanks
:headspin:
  • 3 months later...
I have to replace the boots on mine as well as both sides have split and thrown grease all over the wheel :rofl:
I've pulled both drive shafts out .... can I take them to a CV-joint shop and get them to fix them up? ie. put new boots on, clean the original shafts and put grease in etc?
Thanks ! :(
  • 5 months later...
G'day Jerry,
can you expand on your info for the CV joint boots?
Im going to be needing to do it at some stage soon...
also I need to do the steering rack ones! do you know or have you done it with the repco kit RRB033 I have heard conflicting reports about how good a fit they are with the GTR
would be great to find a way to do both sets of boots for less than a work shop!
thanks....
G'day Jerry,
thanks....
Ben ,
I dont know if you can match the steering rack boots with aftermarket ( i'm fairly sure you would be able to ) .
As for the cv boots , go to any auto shop with a sample boot and they will match it , failing that you can use the universal ones ( you cut to suit ) , there is 4, 2 on each driveshaft . You dont need to pull the shafts off the car to change but you have to release them so you can fit the new boots on . If you never done it before its best to leave it to a workshop as it is a bit of work on the gtr and i dont know your mechanical knowledge .
Why do you say you have to replace them ?Are they cracked ? Are they split ? If they are split you have to do them asap otherwise you get water in the cv's and then you have to replace them as well . The steering rack are not as critical but you should still replace them if they are split .
Edited by wrxhoon
ahhh ok....
mech knowledge is ok, just a hoist would be nice, but I could do it all here as I have now got a nice workshop at home (in adelaide)
as for the boots....
steering is spilt for sure.....
and CVs some grease has come out of a hole somewhere!!!! no idea, cant see it...
but yes they are needing some work!
will look at getting a shop to see to them if they are that much of a bitch!
thanks
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
