Hi Jason, NZM034 is my car... The photo's look good but I wasn't happy with the times it was running on saturday - it's run much faster before... I was trying out some different tread (hence the rims on the back)... as Shane (srt) has said, we'll head down to willowbank again soon! I'll have it back running 12's!
Feel free to add my msn and I'll tell ya more about the car if your interested
Thanks mate!
https://www.sau.com.au/forums/topic/62319-nzm034/#findComment-1177080
Ash you would actually have to do some work up here, instead of just trying to hock off those NS8421P's, which by the way are all GONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :P
hahaha don't you have to have a working skyline in order to post up here (just kidding) cool I will call simon and tell him you need some more. By the way where have you been last couple of times I came in you weren't there. Oh and HUrry up and get your car on the road I want to see it. :D
https://www.sau.com.au/forums/topic/62319-nzm034/#findComment-1188190
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
    • Is it possible to get them dilled and taped if its not there. Same for oil feed and turbo drain, is it easy to get them taped or i should get the supply from somewhere else?
    • I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
