General Vehicle Details
Year – 1996
Make – Nissan
Model – Skyline R33 GT-R
Body style – Sedan
Time owned – 1 year
Car built by ARC in JAPAN and Gavin Wood Australia
About my car – The car started life as a normal R33 GTR till arc in japan sourced a R34 GTRN1 complete motor and turbos this kind of motor is totally different from a standard motor with n1 cams ported head the unbreakable n1 block and so on. ARC fitted one of there own thick bar and plate intercoolers , 16 layered oil cooler kit+remote oil filter and so on till the car was decked out with all the goodies for circuit racing in japan. The car was then sold to me and gavin wood tuned the power FC to run on our fuel and give it a nice safe tune.
ENGINE
Make – RB26DETT
Size – 2.6L
Intake – hks filters / ARC intercooler
Injection – 770cc injctors nismo fuel reg
Management – Apexi Power FC AVC-R BOOST CONTROLER
Turbo – R34N1 X 2
Exhaust – twin Stainless steal 2 ¾”
Ignition – Spitfire coils
Power – 433hp@all wheels
Other details - R34GTR N1 engine
N1 pistons
N1 water pump
N1 oil pump
N1 head gasket
N1 head porting
N1 block
N1 EVERYTHING!!!!!!!!
GEARBOX
Make – STD
MODEL – STD GTR
Modifactions – OS Giken syncros
Clutch – twin plate OS Giken
DIFFERENTIAL
Make – front cusco diff std rear diff
Lsd – yes
SUSPENSION
Tein coil over suspension
BRAKES
Brembo calipers
Dba slotted rotors
Green stuff pads
WHEELS and TYRES
SSR lightweight rims
18X10
Rubber – 265 – 35-18 all round
STEERING
Momo race wheel
INTERIOR
Seat – RECARO
Greddy gauges
6point roll cage
Nizmo speedo
Autometer C2 Tacho
BODY
400r front bar
Trust custom rear wing
Custom Blue Flakes in paint
AUDIO
DRAGSTER 6” splits
Alpine Touch Screen Headunit
Electrical
GREDDY GUAGES
+Oil pressure
+Water temp
+Oil temp
+Front split torque
+Exhaust temp
+Boost
Im happy to take any seriously interested buyers for a test drive or two :cheers:
If anyone is interested please sms or call me (0413 055 811)
The car would make a perfect club racer/track car. or even a street car if u so desired all that power for the road.
ill consider any offer around $58000 mark.
any questions? u can call or sms me or reply to this post.
Thanks
James Melville
https://www.sau.com.au/forums/topic/62344-r33-gtr-trackstreet-r34n1motor/
I have seen this car.. very nice clean looking car.. Good luck with the sale! What car will you get next?
Not sure what i will end up with next still working out a few things.
I still cant belive that one day ill have to say goodbye to the GTR :D
its the best car i have ever owned.
wat an awsome looking car.
Did you realise you put sedan in your description???
good luck with the sale
thanks mate,
had no idea till then that a sedan isnt a coupe.
I have owned too many Holdens, its a habbit. i dont want to go back too !!
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
