This is a copy of a thread I have posted on gtr.co.uk, hope you find it useful.
The hazard warning and rear window demist buttons have never lit up in my car, so I thought I would take a look at them tonight and replace the bulbs in them.
Took about 90 minutes to do, and it must be the most fiddly job I've done yet on the skyline!
I took a few photos while the switches were out so you can see how it's done.
The hazard warning switch has one bulb in it and it should light up when you turn on the headlights.
Once you have the dashboard out and the switch removed, lever off the top cover (see pic 1) with a small screwdriver, be careful because there is a spring and a small piece of plastic for the latching mechanism.
Now you can separate the button from the rest of the switch. Pic 2 shows all the separate pieces of the switch.
The bulb lives in a grey piece of rubber that you can just slide off the lamp terminals. Once removed you need to unloop the lamp wires from the lamp cover, I used the end of a sharp knife to pull the wires until there was enough free to pull the bulb out. Now remove the coloured lamp cover from the old bulb and place it on your new one (60mA 12V). Thread the wire through the lamp cover and loop them back through the holes for the bulb terminals. Slide back onto lamp terminals.
Putting the switch back together was the trickiest bit. The easiest way is to take the top cover and line it up over the button and push it straight down. Make sure the latch mechanism is lined up the same as in pic 1. Turn it over and do the same with the bottom part of the switch, remember to put the spring back in first though. (Not like me!)
The rear window demist switch is exactly the same, except it has two bulbs, blue when the headlights are on and orange when the demister is on.
PART II:
How to fix light in electric window switch:
1. Prize off cap inside door handle, and remove screw. The trim is now just held on with 2 clips and should just lift away.
2. Unclip switch from wiring harness. Now remove 4 screws holding switch onto door trim.
3. Prize cap off window lock button.
4. Remove three screws from back of switch.
5. Lift white plastic cover enough, so that you can use a small screwdriver to prize it over the clips
6. Remove screw holding black connector to pcb. Now for the tricky bit. The bulb can't be removed without taking the black connector off. The easiest way would be to desolder it, or you can try and unclip the connector (Not easy! Involves lots of swearing and brute force :P). First unclip the back of the connector and lift away.
7. Lever the two clips free. Now this bit is very tight and you have to bend the connector up a little so that the cover will slide off.
8. Now you can finally get the bulb out, just give the plastic holder a twist and it'll come out. Unwrap the wire of the old bulb from the holder and replace with 60mA 12V bulb. Swap over blue cover.
Putting it back together should be easy! Just read this backwards :)
Cheers,
Simon.
https://www.sau.com.au/forums/topic/62358-replacing-switch-lights/
Great thread PlasticStan, have done this process myself after realising that the Hazard light button thing is supposed to light up....
Only one other thing to add, watch out for the spring when taking it apart, can go flying out if you aren't careful!
If you are in Aussie or NZ, replacement bulbs can be found at Dick Smiths, part number P8140. They are a 50mA bulb, so are very slightly dimmer than stock, but I don't really notice the difference compared to the other lights in the dash.
These bulbs can also be used as replacements for the lamps behind the R33 climate control buttons.
any idea on the code for a blue replacement led of the same rating?
i want bloo!
yeah, is it easy to put an LED in instead of a globe?
Would be difficult, you'd need to put an LED plus current limiting resistor in, and the space available is about enough for the LED and nothing else! And you need the resistor otherwise the LED will not last very long.
Best to try to find the right coloured sleeve thingy for the globe.
  • 5 years later...
i checked the DSE website they are sold out and the stores that it says have some in stock dont have any left because people steal them and to top it all off P8140 are now a discontinued product.
Any ideas on where might sell the stock bulb?
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
