NSX type R hand built in japan..
goes very damn good for it's lil 3.2 N/a engine
such a great car.
stock to stock
a NSX-R has eaten R34 GTR VSP this was in BMI vids
the NSX-R lost to lambo's in a circuit battle due to straight line speeds of the monster 6L cars.
but managed to kill the lambos in the corners and stayed infront of the 911 TT and the M3 CSL and the 360 Modena with F50 brembos
i personally think it's the greatest japanese sprots car but the price tag is a bit...:P
https://www.sau.com.au/forums/topic/62371-honda-nsx/#findComment-1175643
]']NSX type R hand built in japan..
such a great car.
stock to stock
Ahhh the great 'Super Battle' :kewl:
https://www.sau.com.au/forums/topic/62371-honda-nsx/#findComment-1175646
The handling of NSX is fine tuned by ex - F1 racer Senna
and the first aluminum chassis of the world back in 90's
how much an audi ask for a car with aluminium chassis, even they are now doing it in mass production with today technology?
not to mention the titaninum con-rod in those late model 3.2L engine...
and the much much better balancing job of the engine
good stuff never equal to value for money
i don't rate GTR as a super car but NSX
but i will take a R34 GTR over a NSX
https://www.sau.com.au/forums/topic/62371-honda-nsx/#findComment-1175771
Ok - I've owned both so I feel some what in a position to talk about this topic (and not for the first time one here! LOL)
One of the biggest problems in this arguement is what we are basing the NSX on. Are we talking about NSX's as available in Japan (such as the Spec R) or just whats available here in Oz. An R34 GTR would seriously whip an Oz NSX in any race you want to have.
The main reason why I sold my NSX to buy an R34 GTR was because the Oz delivered NSX was very difficult to do anything with other than what it came stock as without spending a pointless amount of $$$. Apparently the diff's in the normal NSX were not designed to take any extra power. And upgrading the diffs was a very expensive exersize - not to mention that finding anyone that know's what they are doing on an NSX in Oz is also very limmited.
The GTR with very little spent on it so far out performs the NSX that its not funny. If I had access to an NSX R then the story would be different. But we can't get them here.
One thing about the NSX though is the refinement. Its something the GTR lacks. The GTR really is a race car. The NSX is a Grand Tourer. So it depends on what you are after. And it depends on what you define as a supercar. For me - the R34 is much better than the NSX ever was. But my wife prefered the NSX.
https://www.sau.com.au/forums/topic/62371-honda-nsx/#findComment-1176056
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
