I am about to change the spark plugs in my Stagea (R33 RB25DET equivalent) and want to know what spark plugs people use in their R33s and why.
The biggest issue I see across the other threads is people re-gapping or buying spark plugs gapped at 0.8mm rather then the specified 1.1mm
I am going to stick with NGK plugs for my car but am wondering why people actually use the 0.8mm gap over the 1.1mm gap when it comes to the spark plugs. There seems to be many people on here that are advising this and I want to know the exact reasons why as Im certain the standard coil over plug can easy give good enough spark on the 1.1mm gap and am concerned with hesisation under accelaration using the smaller gap as you can see in other cars.
By the way the plugs Im talking in reference to are the Iridium NGK plugs BKR5EIX-11 (1.1mm gap) and the BKR5EIX (08.mm gap). But the gap issue shouldn't matter if copper or iridum I would imagine.
By the way Im running just an average setup of filter, 10psi and cat back exhaust but have plans for full exhaust and frount mount soon.
I use NGK copper BCPR6ES which are pre gapped to .8mm. I changed to gapped spark plugs to overcome the missing problem i was encountering after raising the boost from stock to 1 bar. The gapped plugs solved this problem. They are nice and cheap at $4ea so if they stuff up you can just go chuck a whole new set in for $24.
u probably know but the gap referrs to the "gap" that the spark has to travel to the tip. so shorter distance = quicker sparks = quicker combustions in the high revs. then there are others who say that 1.1 give a stronger spark = better combustions. well this is what ive picked up readin the various threads. im currently runnin NGK BCPR6ES (0.8) too after havin misfire on my old sparkies which died in the ass. im running stock boost and there doesnt seem to be any hesitations.
I am running kinda the same setup as you. I have a r33 RB25det running 10psi but with a turbo back exhaust. I started having issues with the car missing when the boost went over 8psi , I was told that with the increase boost it can cause the spark to be blown out when the air rushes it. Thus the smaller gap makes it harder to blow out. Im not sure why the missing started cause i was running the same setup before the only thing i can guess at is that the coil packs were getting older and thus providing less spark?
Anyway I put some BKR5EIX-11's (1.1mm gap) in my car but the engine still missed when i hit 8+ psi. Then i re gapped my standard plugs to 0.8mm and the problem went away. I now have BKR5EIX's (08.mm gap) on order, they should be going in the car tomorrow. I will let you know if they make much of a difference over the standard plugs at 0.8mm.
I have actuallly tested the difference in plug gaps.........i bought 2 sets of plugs......both the same heat rating (7)...one set were gapped at 1.1 and the other at 0.9........at 0.9 they actually made the engine more responsive and felt more powerful.
Just my personal experience........others may feel differently
OK, so I put a set of NGK BCPR6ES into my RB25DET yesterday. The plugs that were in there before were NGK PFR5G11. I fired the car up and immediately noticed a different tone coming from the engine. Warmed her up then took her for a lap around the block.
The car seems to JERK continuously under acceleration now. When not accelerating everything is fine. The car now sounds like a mild V8. Does anyone know what the problem could be?
Mods are 3' Turbo back exhaust, FMIC, 10psi boost & pod filter.
there have been threads about how peeps get the odd dud sparkies. i remember a thread where someone put 6 new ones in and they were all duds. might be good to take them out again and have a look. sound of a V8 and the jerkin suggests one or more of your sparkies aint workin right.
Cheers mate, I'll pull em out and stick the old ones back in to see what happens! How do I test whether the new ones r duds?
Dont know if Spark plugs can change the way the car drives, but it might have had an affect on something else, like ignition timing for example. Dont now why it would though.
I had this exact same problem when i did my spark plugs. Sounded almost like a wrx on idle but chugged when ever i tried to accelerate. The cause was the coil packs. When pluggin one of the coil packs in the ground wire got bent back and wasn't contacting.
Pull out each coil pack one at a time and check all the connections are ok. Hope this helps.
Upon opening up the cover I found that one of the connections from the loom to a coil pack had come undone.
Put it back together now problem fixed. Thanks guys for the suggestions. Lesson learned: Don't change spark plugs in failing light!
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
