My R33 series 2
ABS motor died so want to just leave it disabled
Thinking of fitting slotted rotors to the front.
I heard that the brake piping bias is 90% to the front on ABS cars
but should be 70% if change to ABS.
Is this right, will I need to change the front to rear bias?
Need some advice.
How do you intend to adjust the brake bias?By buying an adjustable brake bias controller?Call a brake specialist to answer your brake bias question.
Exactly what is wrong with the abs box is it a blockage??Why dont you get it checked out and see if it can be fixed.It's worth a try.Or get a new 1.Or 2nd hand 1 etc...
I did some reading up and as u have confirmed the brakes will still function normally just without the abs.A warning light should also come on your dash telling u that your abs has sh*t itself.
I know nothing about abs brakes.
well you haven't even said whether it's an ATTESSA 4WD or 2WD Skyline, that would help..
The discs shouldn't be any different to any other discs.. take off the old ones, and put on the new. The ABS is a separate issue..
predator
Its a 2wd gtst, thanks.
Trust33
First thing I did was find out from Nissan using their consult device that the reading given is "motor off". Nissan told me to replace it.
The adjustable brake bias controller sounds interesting.
Replacing it - All up to replace it the labour cost is high and I've never experienced the ABS working properly as it was on its way out from the day I bought my car, the on off pulse was so slow, so I'm not sure if its worth fixing.
Does anyone with ABS think it works well in the skyline?
How is the vibration, does it pulse fast enough when it is working properly. For example how much slower vibration to volvo for comparisson.
If the R33 gtst ABS is any good then I guess I'd like to know who can replace my ABS motor unit and charge me less please. I'll supply the brake fluid.
