I'm changing my gf's coolant this weekend.
It's very rusty and sludgy so I got a bottle of radiator cleaner. You add it to the coolant, run engine for 20 min, drain the coolant and then it says to flush the system.
How do I flush the coolant system?
I've been reading that reverse flushing the system is the way to go - so do i just stick the hose up the drain plug and crank up the pressure or what?
Thanks guys
Greg
https://www.sau.com.au/forums/topic/62427-changing-coolant-and-flushing-system/
I saw its best to disconnect the top pipe, have the engine running at idle, and just fill the radiator with the garden hose at the same rate that it empties. When the water coming out turns clear its done. Let the radiator empty a little so theres space for the coolant.
I wonder how UAS do a flush? I read on their site that they only use demineralised water, dosent come from the tap :cheers:
On the side of the block there is a plug to drain the water from the water jackets around the cylinders, dont know if people actually do this or they just do similar to what you have mentioned. In the work shop manual it recomends to undo the plug to let the water drain from there as well as from the radiator hoses.
  • 2 months later...
Another way would be to remove the the Thermo housing (and while its out test the Thermo) and run the pressurised water into the radiator and through the engine. If you have access to an air compressor you could flush out the water after with the air, then reconnect everything (you will need to use a silicone gasket to reseal the thermo housing) and refil with appropriate water and collant.
Cheers
To remove gunk from radiator, it is obviously best to reverse the water flow through it! Normally, the water flows from top to bottom. If you remove the radiator cap, and the bottom hose, and use a garden hose from the bottom [preferably sealed as much as possible - wrap a rag or something around it.., it will remove UPWARDS that which has lodged in tubes from above.
The thermostat will stop flow to other parts, so that this will concentrate on cleaning rad. Then use other suggestions to flush out block,etc. Think about where the flow is going when you're doing these things, so that you don't dislodge rubbish from,say, block,and deposit it in radiator.
Remember that larger pieces may be dislodged than can't pass thru radiator tubes, so you can actually make it worse, if you're not thinking.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
