R32 GTST for sale in Perth
Pozza
 Share
Hi everyone i'm a long time lurker. I have just started to get my shit together to buy a skyline, and today me and a mate have gone looking for our new rides. We have driven past a lot of car yards and have only seen 2 R32s which were both autos :s. Does aone know where we could go see some R32s today. Thanks guys
im actually looking for a 33 but my mate is prolly looking to spend up to about $14000 for a fairly stock example.
Pozza: try Extreme Machines in Willeton, got my R32 GTST there, it's a good one. Talk to Col, think he's got one in the yard at the moment with a bit of fruit on it. Might be a bit pricey for your mate, but there's heaps there to look at if you're chasing an R33 as well.
yeah, i love that place always have good imports
on another note has anyone seen the sunday times? look under nissan and find skyline, Mega Motors is selling R33 and R32's for under 10 grand i think they have just got imported but im not sure...anyway go check it out!
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
