I got falken ziex 265/35/18 on the rears I find then realy good in the dry but in the wet i think they are just crap i was told thay had a high temp rating and in the wet they struggle to get heat in to them thus no traction cheers.
  • Replies 57
if you want good rubber go and see if you can get some Re55s but they come at a cost and they a an import tyer. last i got them for was $480.. or you can do the top of the range Falken's and pay $525 for 275x18x35 for the rear...that's each by the way .. i have Falkens on the rear of mine great tyer but do not do to many burnout's ..
Falken 326 must be the most common skyline tyre out there....compliancers put them on because they are cheap and come in big sizes. They are terrible.
Falken ST115 are also appalling, which is even worse when you think they promote them as sporty.
Falken FK451 on the other hand are excellent tyres....go for em if you can get em, about $450 each.
For Re55s, they are brillian but will wear really quickly, 5-10000klm only. SAU NSW club members can get them in 17s for about 400 a corner from Gordon Leven
They are probably a little worn as well .
Any car with wide tyres at the front will tram to some extend , i got 265 's it trams too , it even trams with the stock 245's but not as much .
i just changed from some of the old Michelin pilot SX (not available now) and everyone i spoke to said Yoko C-drives were the Sh!t, and that once i used them id never use another tyre. Well thats the biggest load of crap!
unfortunately i did little research and just got the C-drives. Soon after learn that they replace the A539's, which while good, are never going to be michelin pilots!
These tyres ride super quiet, and are really comfortable, but on hard braking they lock up much easier than the pilots. Turn in and bite is far less positive, and on fast sweepers the car seems to subtly creep out and not hold the line.
Im not saying the C-drives are bad tyres, but when comparing them to a tyre such as a pilot then you see why you pay so much for the michelins.
while you can find performance tyres on a budget, the "best street tyres" will always be the most expensive each company has to offer! eg, im sure if you can foot the budget you wouldnt be disappointed with top level yoko AVS's, Pilot Sports, and Bridgestone Potenza's.
i saw someone mentioned yoko AVID S306's as good tyres! Sorry but have to disaggree! they are good if you like quiet tyres, but not if you like grippy tyres. I ran a set to about 50% then changed them for some potenza's. Bottom line, S306's are yoko's bargain "ECONOMY" passenger car tyre. Not what you want if you drive a car with some power. very easy to brake tracktion and lock up under braking.. these were on 19's, so probably exacerbated by the ultra low profile.
The latest Wheels mag tests a variety of tyres and the performance tyre which one was the Goodyear Revspec RS-02.
http://www.goodyear.com.au/passenger-tyres.htm
The Michelin Pilots came in a close second. From memory these tyres have either won or come second in every tyre test by Motor and Wheels over the last few years. Of course they cost plenty.
I wanted to try the Revspec on my Peugeot 205 GTI but they don't come in my size (195/50/15). I currently have Dunlop FM901s on my grey GTR and have to buy some new tyres to fit the R34 GTR rims I've got for the white GTR. Don't know the cost of the Goodyears yet. I'll make some calls and post the results.
Re the Kumho Ecsta's........ OK so most everyone thinks that they're sh!t but in what way ? And what version ? 711, 712 etc ?
I guess I'm asking are they OK for cruising and the ocasional belt down Putty Rd ?
well we used to run the khumo 711 on the daewoo race cars, and the 712s in one enduro as well. They were good tyres, I'm not sure of how the price compares (we were paying $250 for 205/16s) 711s about 2 sec better than the 712s around wakefield.
HOLY CRAP !! $250 for 205/16's ?!?!?! :crazy:
Is it just me or is that a lot of $'s for a little hoop ?!?!
So what would I be looking at for 255/40/17's ( I think the ones I'm looking at are Ecsta MX KU15 ) ?
At the moment I'm on Falken ZE512's that cost $250ea for 255/40/17 and $150ea for 235/45/17.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
