Hi
I have a Trust TD06-17C turbo for sale. It is T3 flange, internal gate.
Good upgrade for RB20/25/30
Rated at 380ps according to various websites
Good condition
$700
in Syd
email too_much_boost at iinet.net.au for pics
https://www.sau.com.au/forums/topic/62443-fs-td06-17c-rb2025-upgrade-turbo/
some questions...
firstly easy one - why are you selling?
good condition - not ... excellent contion? and why? :rant:
and hard question, due to intercooler piping having to fit SOMEWHERE in my 260z, the front (compressor?) on my turbo was rotated... does this mean i have to have the wastegate actuator modified on your turbo to fit it?
i can undo a few manifold bolts on either of a turbo to fit a new one, but i can't weld... - but i can organise friends who can weld :>
I'm selling as i went SR instead of RB.
If i posted it as excellent condition, people expect it to be new, and if it isn't they complain. I am realistic about the condition by saying it is good condition. The turbo has normal wear for its age but has no damage to the wheels or housings.
If you rotate the housing, you will probably have to figure out a way to remount the actuator
actually here is an interesting idea, is it just the the fact that it has t3 flanges that make it a bolton swap to the rb20 turbo? or does it also have the same external dimensions? cos then i could swap my modifed actuator on - but then again, thats a bad idea maybe.
and by bolton - is the dump pipe flange the same as the stock rb20 turbo?
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
