hey guys
im having a problem with my system. when i hooked it up all the speakers work but only the back left one doesnt. i have checked all the wireing over 1 million times. i got my amp test to see it thats the problem but it wasnt. some people say that some time the blue RCA wires **** up. i cbf removing the wires again so is there another way to replace the RCA connections?
cheers
bill
https://www.sau.com.au/forums/topic/62453-help-needed/
Process of elimination?
Hook up the wire coming from the speaker that doesn't work, to the output on the amp taht you know does work (ie hook up Rear Left speaker to Rear right output), if sound comes out, you know the wiring to the speaker is fine and you rule that out...
Then put the rear right RCA input into the rear left RCA, if the audio then works out the rear left channel, then you can assume either the RCA cable is stuffed or the output for the rear left is stuffed on the headunit, or its come unplugged at the headunit, or a setting in the headunit is wrong...
i'm sure you get the picture :D
https://www.sau.com.au/forums/topic/62453-help-needed/#findComment-1176830
