  • 1 year later...
  • Replies 54
Posted Images
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
thanks Dave.
I probably should have posted something like this earlier, but I thought that the dates of the thread would do the talking for me.
About the only things I have left are the suspension and the power window control switch for the driver side door. If anyone's interested in those 2 items only, feel free to call me. Everything else = gooooooone a very long time ago.
Cheers,
Sam
  • 1 month later...
I'm ready to sell most bits off my wrecked R32.
Main part I want to get rid of is the read half of the car (from the back of the doors to the rear). This includes exterior panels, window, wiper, rear bar etc. No lights as I sold them. Does not include wheels or sub frame or diff or anything (although the subframe is available for sale too). So yeah, it's basically the rear half of the car without the bits on it. Someone make me an offer on this and come pick it up smile.gif
I also have the following parts off the car and ready for sale:
Stock intercooler
Passenger side rear light.
Full interior carpet (in very good condition, grey in colour)
Interior roof trim
Rear seat (excellent condition)
Body kit consisting of side skirts, front lip and rear side skirts
As well as plenty of small bits and pieces such as rear view mirror, indicator control stick, boot release lever etc. If there is something you're after, let me know cause I might have it.
I posted an add here a while ago. For those who I didn't get back to, I apologise. My computer crashed and I had to format my harddrive sad.gif
Please don't ask me technical questions about any of this stuff cause I wont be able to answer them as i'm not very knowlegable in terms of cars.
I am located in the lower north shore of sydney.
If you interested in anything here, or something else I might have, please email me (sambo at zgeek dot com) or phone me 0418 233 525 (please, no sms, just call me, I don't bite).
do u have a stock exhaust for 32 GTS-T. cheers.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
