  • Replies 70
mini, with a 1275cc motor, race turned extrators full exaust system 3 in ext tip, water cooled inlet manifold, large su carb, uni fillter, slightly lowered, head work, oversized valves. Thats all i can remember now, and i have still got it.
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1177910
I had an '85 Alfa Romeo Alfetta 2L, prev owned by my grandfather.
Only mods i did to it were custom busted gearbox and huge painted over rust patches...
Couldn't begin to tell you the amount of troubles i had with that prick of a thing, but even now when i see one i get all nostalgic. Still would love to own an alfa again, there's just somethin about your first car....
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1177941
1st car was a mark one escort 2 door. had a 1600cc, cammed, big webber twin throat, extractors and massive 14 x 8in wide rubber (anyone who know the original tyre size will appreciate this!!).
Wasn't too bad in the poke department, but was glued to the road in the twisty stuff. had so much fun in that car. (would still have one now!)
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1178017
My FC3S Mazda RX-7 is my first car.. I've done too much to it to list. Now that it's finally been tuned after running the new engine in I'm loving it :rant: First time in the year+ I've owned it that it's run properly.
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1178029
HQ panelvan.
Prem front end, painted in the backyard without masking up (just wound down the windows), 173 ci of holden muscle (well, not really), lowered with lowering blocks that sometimes fell out, GTS dash and steering wheel worth more than the rest of the car, orange plastic emergency fuel cap, m20 4 speed conversion.
Twas a good car till it got firebombed.
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1178047
A devil yellow 77 mini S, 998cc, 10thou over flat top pistons, big cam, port and polish, oversized valves, twin SUs, extractor and 2in exhaust... 10x5" polished 4 slot mags, 10" sub in the boot.
Was still slow, but $5 fuel went a long way and it handled like nothing else. Most fun I have ever had in a car!
https://www.sau.com.au/forums/topic/62489-your-first-car/#findComment-1178094
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
