'90 Nissan Patrol with RB30DET that previous owner installed it so relaible i never need to pop the bonnet to check for fluids, 12 months since i first bought it...
Might have to give up for another RB Nissan
Cheers
Grant
  • Replies 70
I'm probably gunna get bagged out for this, but my first car was a 1978 VB sl/e commodore with a worked 308, turbo 400 tranny and a nine inch. It ran 13 sec quaters and had a top speed of about 240km/h.
I've still got it and am planning to rebuild it (make it even faster), as soon as I finish saving up for an R32 GTR.
95 Hyundai Excel 3 Door Hatchback......Laugh all you like. Punished everyday of it's life, has driven over 310 thousand K's and still going strong. It has been the best investment I have made to date.
Mods: One big arse stereo (in it's day). Infinity Kappa splits, 6X9's and a 12 inch in the boot. Recall racing a "Devil Yellow Mini". Now those were the days. LOL
1979 Torana
- 202 stage 1 with a stage 2 cam (about 25/65), Genies, Holley, the usual stuff
- M20 & about 3 or 4 diffs (kept braking them).
- yellow with a black bonnet, hotwires (heheh) & no bumpers
- plenty of camber 225s on the front, 185s on the back for dodgy dorifto Oz Style
My first car:
GTR R32 T88-33d, Cams, etc etc etc....
400kw@ wheels
Lucky first car aye!!!
So your actually dead right & this is like the brother or relative telling people what your car was? FMD 400kw @ the wheels for a P plater is a tad extreme.... I hope Daddy didnt buy it.
:headspin: I'm amazed at the amount of PPl who can afford the $$$ to get something pretty flash as a first car!?!?
1. is it that either someone else fronted up with the money for you, or
2.you used other peoples cars for most of your early driving life, or
3. you lived at home riding the train / tram / getting a lift, not spending the money that you earnt??? :headspin:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
