Cusco R32 Handling Upgrade Combo
You keep asking this question, and now I understand why. But I don't understand how jamming the yoke an extra inch into the gearbox is a thing.
Ill go with end of Jan. I think he wants his roof first...
By SeanR32GtSt · Posted
I have no plans going with a FFP on my vehicle, hence why I was going to put the sensor on that pipe by the bov. -
It's not as thick as you think. I drilled and tapped mine for the IAT that came with my Haltech PnP kit but ended up ditching it and getting Plazmaman plumbing with a dedicated bung welded on. The pitch on the M14 x 1.5 sensor left very little thread engagement.
I have myself an ABS r34 Diff for my R32. The nose of the diff is about an inch longer than the original. This causes the tailshaft to be too long. the rear section of my Tailshaft is about 800mm. Ideally I'd like to find a rear tailshaft section that is shorter but I have an event next week. What's your thoughts on welding some 3mm flat bar to the top of the center bearing mounting tabs and drill holes 1"back so the center bearing will mount forward a bit more?
