Steel front wheel, most likley ceramic exhaust wheel. - stock turbo ? I carn't remember if the comp has ceramic wheel or not ?
I don't think it makes a difference anyway, inless its a R34 turbo which is nylon compressor wheel aka plastic.
If its got an exhaust wheel made of ceramic then you can't be boosting over (12psi max) for too long. otherwise it'll end up in you'r cat.
If its a high flow turbo with a steel exhaust wheel then you can run upto 17psi max. But i wouldn't recomend doing that inless you have the usual modifications done, including fuel pump and aftermarket computer. - stock ecu has fuel cut anyway at 14psi.
:rant:
Jun
https://www.sau.com.au/forums/topic/62531-95-r33-series-15/#findComment-1178298
