Can Some1 Please Help Me With Finding Some Kind Of A Plan (drawings) Or Whatever I Need 2 Show Me How To Bend Pipes For It, I've Got A Pipe Bender And The Rest Of The Tools I Just Need A Dimensions Etc. Or If Theres A Website That Could Help Me That Would B Even Betta, Thanks Guys, I Know Theres Some1 Out There That Can Help Me
https://www.sau.com.au/forums/topic/62570-intercooler-for-r33gts/
Custom intercooler piping is usually made up using preformed mandrel bends tig welded together.
Normal press bends vary in diameter through the bend and aren't usually bent as tightly as mandrel and doughnut bends.
I've been looking into making up my own aluminium piping for my R32 and after pricing the 90 deg. bends(7for$180), pipe(1.5m $30),tig welding(maybe <$100) and silicone joiners(4x$20ea)/reducers(2x$40ea) so now I'm thinking of going in on one of the group buys for $500.
You maybe able to do it cheaply in mild steel exhaust tube but I don't know if the pipe bender you have can give you the type of results you would be happy with.
Do a search in the tutorials as I saw a 'how to' thread there for a 32 using the behind the intercooler return pipe which is easier than the conventional piping route.
Hey guys, just a quick note as i just did mine too, i would'nt recommend mild steel as such because under heat and with moisture it will rust fairly quickly and you don't want that shit in ur engine hehe. I did however find that some exhaust shops have "aluminised" mild steel mandrel bends(about $20 ea) or as i did you can just buy a mandrel tailpipe with heaps of bends in it and cut what you want! All up the pipe cost me $75, not bad i thought.
Anyway good luck....
for me its pretty cheap, i work for stainles steel stockist, so i got stainless pipe 316 grade polished for 18/meter and 2 90degree elbows, now i need an intercooler, does n e body know where 2 get it @ really good price
Get one from Raf in the group buys.
I got mine from him a few weeks ago. Now they are even cheaper.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
