Watz the deal with Today Tonight?????
What's that thing abt beating speed cameras???? I missed tonight show coz had to stay a bit late at work n da bloody traffic takes me 45 mins to get home &@#$%@!!!!! It should normally took me no more than 25 mins home......
https://www.sau.com.au/forums/topic/6259-watz-the-deal-with-today-tonight/
it looks fairly expensive for something that's not even a proper radar detector... it relies on a database of known speed camera location (that is, if someone bother maintaining & updating the database continuously) and using GPS let you know if you are approaching any known location....
It wont know if any cops decided to park their car at a side road and start using their radar.... unless they are always at the same spot 24/7 and someone put information abt that place in the database...
Not only u need to turn it off, you had to plug it off and hide it quickly as well, and dun let your ciggy lighter left open coz that will raise suspicion... any how after u've done all that, if they suspect you they can always search the car and find it, then you'll have to pay the hefty fine.
Speaking of ciggy lighter, my one is missing, which is not good actually. Not that I smoke, but I just dun feel like leaving my car ciggy lighter plug with nothing in it. Looks dodgy like having a radar detector somewhere in the car. I can't seem to find any replacement in K-Mart Auto/Repco... Guess have to go to nissan dealer n order one from them?
You can certainly buy a novelty Nismo cig lighter or something, but I couldn't justify buying one of those. Very ricey.
Does a radar detector have to be mounted on your dash (line of sight?). I read in another thread someone's detector not only picked up radar traps but police cars too! How can it do that line of sight of the police car isn't emitting anything? (except radio waves - which isn't line of sight)
go buy those little torches that recharge when plugged into the lighter hole.... they ALWAYS come in handy!
i dont smoke either so thats what i got for it... dont remember where i put it tho... got such a bad memory.
funny thing is i lost my phone again... im too scared to look under the seat again to give myself a little more credit as to loosing it there again :) its been missing for like a week now :cool:
I just checked out that site and had a quick glance at the nismo stuff. Is it just me or is nismo stuffy totally over priced???? i mean heres a prime example: a "nismo" cap the same as any other cap around however with the word nismo on it can sell for $89.00????? how can this be. ]
And I thought airport food was expensive
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
