rare? almost all 89 imports have a set of em on them.
anyways, interested in pics or condition report as I'm starting up a headlight conversion process and need a set.
The globes are not gone, i was talking about the globes in my new headlights. They should be fine.
[/size]
Sorry, have had a lot of PM, so PM me again if you want them. Not too sure about postage - upi just tell me how you want me to send them.
