  • Replies 80
LOL it was a DR30 and in car film . Its on the video "The Great race , the Turbolent years Bathurst 1986 - 1992" . Great driving for basically an overgrown Datsun 1600 with a top endy FJ20ET .
It was interesting to watch the R31's race , they appeared to be driven on the rev limit everywhere .
show me graphs of an rb20 and an sr20 with the same turbo, this will be a good comparison... not based on whether 6 cylinders is better then 4, but rather a direct engine to engine comparison
i think i can answer this one
2 180sx's....one has a 1992 SR20DET redtop with a HKS2530 @ 1.2bar, 600x300x80mm FMIC, 3" exhuast, apexi intake, power FC, HKS 550cc injectors, walbro 550HP pump, OS giken twinplate Clutch - on a very convservitive dyno (at a dyno day) it made 191.8rwkw. stock cams/internals
the other 180sx, has a 1992 RB20DET, with a HKS2530 @1.1bar(same turbo), 600x300x80mm FMIC (same IC), 3" exhuast (same), K&N intake, GTR fuel pump, stock injectors but a FPR (fuel pressure regulator) and a SAFC tuned with the stock computer. it made (at the same dyno day, a few mins after the other 180sx) 192.0rwkw. stock cams/internals
virtually identical power - the torque curves were interesting.....the SR20 was higher untill 4000rpm where the RB took over.....so the SR has the lower end...but it fell away from 6000rpm...where the RB stayed strong to 8000rpm. i worked out the "approx" area under the graphs....the RB had it by about 10% more...due to the wider power band.
now...when racing....from a standing start....the SR wins untill mid-end of 2nd gear, where the RB pulls on it....then by the time 4th comes...its pulled 1.5-2 lengths - its a similar situation when racing supra's...RB takes over in 2nd and continues to pull away...on a rolling start its RB all the way...from 110kph in 3rd gear (4500rpm in the RB , PERFECT from launching from) it nails the SR
the top end of the RB helps here......
i guess u should come to ur own conclusions about these "results" :(
i'll have some results for this thread next week.
rb20det stock internals
HKS gt2530
cam gears
gtr pump
3 inch -> 3 1/2 inch exhaust
ARC fmic
nismo fpr
gtr 444cc injectors....about to be installed
splitfire coil packs
power fc .....about to be installed
Blitz ebc (running .9bar)
hoping for some good response and about 190rwkw
hopefully next week to be taken to jim at CRD to put the finishing touches on it. I'll keep you guys posted on how it goes.
also id like to add
the 2 cars are VERY similar in handling!!!
the RB seems to have made little to no difference
Roy : the RB20 180sx is going into the shop on monday :), injectors, wolf 3d management, tune @ 1.3bar
glad to here that some one else realizes that they handle just fine with the rb20 up front.
over here stateside there is a stigma about the rb series being "massively" heavier thus making your handling crap.
i had no problems with my car, and it was tons of fun to drive, especialy sideways.
My R31 GTSR was returned to me on Monday.
Mods are: GTR injectors, walbro pump, custom fuel rail and all new lines. Exhaust, pod and ecu.
The rest is standard, remembering GTSR had a TO3/4E from factory.
I also removed all the butterflies and the spindle from the sandwich plate between head and inlet manifold.
Results were 225rwkw @ 13psi and 170rwkw @ 6-7psi.
correct - dyno runs are only good for comparison if 2 cars are run beside each other
the 2 cars that i compared have both made over 220rwkw on different dynos
i just used the 190rwkw runs as example as thats what they both made a few mins apart on a the same dyno.
Regarding the 220 on another dyno...exactly. There is another thread at the moment stating a certain power level...and from the experiences of a friend his car made 20rwkws more then what his car typically makes...so comparing power figures from different dynos is a waste of time.
A lot of ppl claim massive wheelspin probs at 200rwkws in an R32 GTST, so with 222rwkws and no wheelspin at all in 2nd let alone 3rd, i question my power figure:(
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam camp bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
