  • Replies 80
LOL it was a DR30 and in car film . Its on the video "The Great race , the Turbolent years Bathurst 1986 - 1992" . Great driving for basically an overgrown Datsun 1600 with a top endy FJ20ET .
It was interesting to watch the R31's race , they appeared to be driven on the rev limit everywhere .
show me graphs of an rb20 and an sr20 with the same turbo, this will be a good comparison... not based on whether 6 cylinders is better then 4, but rather a direct engine to engine comparison
i think i can answer this one
2 180sx's....one has a 1992 SR20DET redtop with a HKS2530 @ 1.2bar, 600x300x80mm FMIC, 3" exhuast, apexi intake, power FC, HKS 550cc injectors, walbro 550HP pump, OS giken twinplate Clutch - on a very convservitive dyno (at a dyno day) it made 191.8rwkw. stock cams/internals
the other 180sx, has a 1992 RB20DET, with a HKS2530 @1.1bar(same turbo), 600x300x80mm FMIC (same IC), 3" exhuast (same), K&N intake, GTR fuel pump, stock injectors but a FPR (fuel pressure regulator) and a SAFC tuned with the stock computer. it made (at the same dyno day, a few mins after the other 180sx) 192.0rwkw. stock cams/internals
virtually identical power - the torque curves were interesting.....the SR20 was higher untill 4000rpm where the RB took over.....so the SR has the lower end...but it fell away from 6000rpm...where the RB stayed strong to 8000rpm. i worked out the "approx" area under the graphs....the RB had it by about 10% more...due to the wider power band.
now...when racing....from a standing start....the SR wins untill mid-end of 2nd gear, where the RB pulls on it....then by the time 4th comes...its pulled 1.5-2 lengths - its a similar situation when racing supra's...RB takes over in 2nd and continues to pull away...on a rolling start its RB all the way...from 110kph in 3rd gear (4500rpm in the RB , PERFECT from launching from) it nails the SR
the top end of the RB helps here......
i guess u should come to ur own conclusions about these "results" :(
i'll have some results for this thread next week.
rb20det stock internals
HKS gt2530
cam gears
gtr pump
3 inch -> 3 1/2 inch exhaust
ARC fmic
nismo fpr
gtr 444cc injectors....about to be installed
splitfire coil packs
power fc .....about to be installed
Blitz ebc (running .9bar)
hoping for some good response and about 190rwkw
hopefully next week to be taken to jim at CRD to put the finishing touches on it. I'll keep you guys posted on how it goes.
also id like to add
the 2 cars are VERY similar in handling!!!
the RB seems to have made little to no difference
Roy : the RB20 180sx is going into the shop on monday :), injectors, wolf 3d management, tune @ 1.3bar
glad to here that some one else realizes that they handle just fine with the rb20 up front.
over here stateside there is a stigma about the rb series being "massively" heavier thus making your handling crap.
i had no problems with my car, and it was tons of fun to drive, especialy sideways.
My R31 GTSR was returned to me on Monday.
Mods are: GTR injectors, walbro pump, custom fuel rail and all new lines. Exhaust, pod and ecu.
The rest is standard, remembering GTSR had a TO3/4E from factory.
I also removed all the butterflies and the spindle from the sandwich plate between head and inlet manifold.
Results were 225rwkw @ 13psi and 170rwkw @ 6-7psi.
correct - dyno runs are only good for comparison if 2 cars are run beside each other
the 2 cars that i compared have both made over 220rwkw on different dynos
i just used the 190rwkw runs as example as thats what they both made a few mins apart on a the same dyno.
Regarding the 220 on another dyno...exactly. There is another thread at the moment stating a certain power level...and from the experiences of a friend his car made 20rwkws more then what his car typically makes...so comparing power figures from different dynos is a waste of time.
A lot of ppl claim massive wheelspin probs at 200rwkws in an R32 GTST, so with 222rwkws and no wheelspin at all in 2nd let alone 3rd, i question my power figure:(
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
