Hi all,
I'm in the market for some new coil overs as my current ones are not in the best of shape.
I have been told that a koni adjustable (not height) with my current Apexi springs will be the go.
What i want to know is what setups have other r32 drivers got and what do they thinkl of them??
Lets hear some feedback.
https://www.sau.com.au/forums/topic/62640-best-setup-for-r32/
i didn't think whiteline made a kit for the r32?
what do they price the kit at??
Because i got qouted $1,500 for the lot (Coilovers + Strut tops + Install - Alignment etc)
That's not "the lot", for a Skyline that really handles you need;
Stabiliser bars, front and rear
Adj Camber bushes, front and rear
Adj Caster bushes
Rear subframe bushes (pineapples)
Front strut brace
HICAS removal
Finish it off with Whiteline springs and Bilsteins shock absorbers. Once fitted, set up the suspension geometry properly (that is not a simplistic toe adjustment at the local tyre service).
Hope that helps:cheers:
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
