I might be wrong, but i think my r32 gts-t s2 has a resistor pack on the pass side strut tower.
I am hoping to remove this and replace it with a gtr one that should arrive tomorrow. I also changed the plugs to bosch ones, they are much nicer and come on and off without the fuss of the standard ones.
  • Replies 153
I will be installing gtr injectors and r30 resistor pack this week before my tune on thursday and just want to make sure this is the correct way. Can anyone confirm that this pic i made is the correct wiring? :)
Also, it doesn't matter which injector is wired to each wire on the resistor pack correct?
Thanks
Dont know if this is the same thread I posted in before, but Ive been running my RB20 since May with GTR injectors with the Apexi ECU and no resistor pack. Works fine. Others have run the same for years and no problems. My car was tuned at Pro Auto here in Hobart and they have done loads of cars. None of us that race them here in Tassie run resistors, one bloke had them and took them off.
3rd Place Targa B 2008
Edited by johnGTS-t
AP Engineering power FC?
i would like to kno if this will work too, saves a lot of time with re wiring thats fo sure!!!
The resistor pack on the passenger side tower is for the fuel pump speed controller.
  • 1 month later...
ok so if i put r33 gtr injectors into a rb20 and have 6 inline resistors (one for each injector)
ie dont use a resistor pack - but use jaycar or something ones instead
anyone know what which resistors i'll need?
if not i'll just measure resistance in current ones, then gtr ones and then get resistor to make up the diff?
thats the ohms - what about watts?
I strongly recommend you get your hands on a copy of the R32 GTST/GTR wiring diagram. The fact that the two engine types are on the one wiring diagram makes it very easy to suss out the wiring. You can get the diagram from rb20det.com or megalla.com
anyone have this???
edit: oooh oooh ive got the R32 engine manual pdf - which has rb20det and rb26dett
  • 3 weeks later...
hey guys i had my GTR injectors cleaned and flow tested today all came up sweet, i replaced the pintl caps o rings and the other couple of rubbers require so all is good to go. does any one know where i can get the resistor pack from? im located in Adelaide the dude i bought the injectors off said that the injectors were low resistance does that mean that there are different types of gtr injectors? mine came off an r32 gtr. just curious.
can some one supply me with a picture of the ballast resistor pack and a picture of where to mount it in the standard position. id really appreciate it as i have no idea lol.
cheers guys BEN
Edited by BENDERS32
Ben - no afaik all R32 GTR injectors are the same - difference is the resistance compared to R32 GTST ones
I had mine (the GTR injectors i bought for my GTST) leak and flow tested on the weekend and put them in on the weekend
(and didn't have a resistor pack so made one)
think of it like this
R32 GTST injectors have a running resistance of ROUGHLY 12 Ohms
R32 GTR injectors have a running resistance of ROUGHLY 2 Ohms
so to make the GTR ones work in the GTST you need to add another 10 Ohm
so for each injector you add a 10 Ohm resistor
ps. sorry have no pics of said GTR resistor pack as ive never seen one and dont have one :P
  • 2 months later...
Does anyone know if you can run low impedence injectors in an rb20det silver top with a microtech lt12s ecu without doing the resister pack??
is there a function in the computer to set low or high impedence???
  • 1 month later...
Hey roy,
Thanks for the great tutorial. Helped heaps. Was a little confused when my resistor pack only measuered 6.7 ohms but checked it against a mates gtr pack running in his car and was the same. I can see why some people say that they have low impedance injectors without the ballast resistor. Throughout this topic it is stated that you need to make up the difference which is roughly 10 ohms. Not true..... The standard resistor pack out of a 32 gtr measures only 6.7 ohms so with the gtr injectors it only comes to roughly 9.3 ohms give or take. Elsewhere I've read that high impedance injectors run between 12 and 16 ohms which makes sense because my GTST injectors measured 14.4 ohms. I installed my resistor pack and gtr injectors two days ago then drove alll the way too sydney without a problem. Just wanted to put some figures out there so people know roughly what to expect. Any questions just PM me :(
Thanks again ROY, absolute legend for the tutorial :thumbsup:
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
