  • Replies 153
Cant remember if ive posted it in here before;
This is the method I came up with for the GTR injector wiring. Much easier than the explained method in this thread!
Pretty much, find the common 12v wire using a multimetre and wire directly off the plug. Saves the effort of stripping back all the wiring etc
thanks rekin!!yeah thats a top diagram..
i'm not using the gtr ballast resistor just 6 individual resistors..
so pretty much just putting the resistors on the positive wire before each injector.
or rolls, you think it shouldn't matter either on pos or neg.?could you explain?
cheers!
What a resistor does is it causes a voltage drop and hence drops the current flowing through the circuit, as the current is the same for all elements in a loop (battery > injector driver > injector > resistor > battery ground) and the aim is to lower the current to stop the injector driver burning out it doesn't matter where in the circuit it is placed, it will have exactly the same effect.
Edited by Rolls
also. when fitting the actual injector.did people remove the O ring on the bottom of the gtr injector, so the fuel rail can screw in all the way (the gtr injectors seem real tight)?
there already is a rubber seal in the head of the rb20, because the stock injectors dont have this O ring attached to the injector itself.
ok i'm putting r32 gtr injectors into my rb25det & i've noticed the bigger/bottom O rings on the engine side (NOT the fuel rail side), the O ring hole is to large for the injector to sit in place! so what O rings should i use the rb20 or gtr O rings?
cheers luke
You also need an aftermarket fuel rail as they are top fee, I got some custom spacers machined up personally for the bottom so they would fit.
yeah thats already done. just trying to work out ow to get them to fit properly.... what did your spacers look like? can you pm me a pic by any chance?
  • 7 months later...
It's some really fancy fabric electrical tape that my auto-eleccy mate gave me.
I grouped them into 2 layers of 3 resistors, cut some ally to use as spacers/heatsinks. Ally spacers on the bottom, in between and on top of the resistors. Used thermal paste between it all and taped either end and longitudinally with the fabric tape (also acts as a damper to take up the minimal slack between the assembly and the case) then thermal pasted the exposed ally top and bottom so that the case can be used as a heat sink too.
I was quite concerned with the assembly moving around and any exposed wires contacting the case (hello fire). The fat power feed to the resistors I stripped back quite far, split it into two and ran three resistors to each with all exposed wire heat shrunk all the way to the resistors.
I have made a new loom just for the power feeds to the injectors, just need to extend the original injectors earths and then crimp the plugs on. My autoleccy mate sourced me some brand new Bosch plugs with seals and boots to suit the GTR injectors and let me borrow his terminal crimper :D
  • 1 month later...
hey mate ive just acquired some 33gtr injectors to go into my rb20 what resisters did you use? as i want to make one as well.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
