I might be wrong, but i think my r32 gts-t s2 has a resistor pack on the pass side strut tower.
I am hoping to remove this and replace it with a gtr one that should arrive tomorrow. I also changed the plugs to bosch ones, they are much nicer and come on and off without the fuss of the standard ones.
  • Replies 153
I will be installing gtr injectors and r30 resistor pack this week before my tune on thursday and just want to make sure this is the correct way. Can anyone confirm that this pic i made is the correct wiring? :)
Also, it doesn't matter which injector is wired to each wire on the resistor pack correct?
Thanks
Dont know if this is the same thread I posted in before, but Ive been running my RB20 since May with GTR injectors with the Apexi ECU and no resistor pack. Works fine. Others have run the same for years and no problems. My car was tuned at Pro Auto here in Hobart and they have done loads of cars. None of us that race them here in Tassie run resistors, one bloke had them and took them off.
3rd Place Targa B 2008
Edited by johnGTS-t
AP Engineering power FC?
i would like to kno if this will work too, saves a lot of time with re wiring thats fo sure!!!
The resistor pack on the passenger side tower is for the fuel pump speed controller.
  • 1 month later...
ok so if i put r33 gtr injectors into a rb20 and have 6 inline resistors (one for each injector)
ie dont use a resistor pack - but use jaycar or something ones instead
anyone know what which resistors i'll need?
if not i'll just measure resistance in current ones, then gtr ones and then get resistor to make up the diff?
thats the ohms - what about watts?
I strongly recommend you get your hands on a copy of the R32 GTST/GTR wiring diagram. The fact that the two engine types are on the one wiring diagram makes it very easy to suss out the wiring. You can get the diagram from rb20det.com or megalla.com
anyone have this???
edit: oooh oooh ive got the R32 engine manual pdf - which has rb20det and rb26dett
  • 3 weeks later...
hey guys i had my GTR injectors cleaned and flow tested today all came up sweet, i replaced the pintl caps o rings and the other couple of rubbers require so all is good to go. does any one know where i can get the resistor pack from? im located in Adelaide the dude i bought the injectors off said that the injectors were low resistance does that mean that there are different types of gtr injectors? mine came off an r32 gtr. just curious.
can some one supply me with a picture of the ballast resistor pack and a picture of where to mount it in the standard position. id really appreciate it as i have no idea lol.
cheers guys BEN
Edited by BENDERS32
Ben - no afaik all R32 GTR injectors are the same - difference is the resistance compared to R32 GTST ones
I had mine (the GTR injectors i bought for my GTST) leak and flow tested on the weekend and put them in on the weekend
(and didn't have a resistor pack so made one)
think of it like this
R32 GTST injectors have a running resistance of ROUGHLY 12 Ohms
R32 GTR injectors have a running resistance of ROUGHLY 2 Ohms
so to make the GTR ones work in the GTST you need to add another 10 Ohm
so for each injector you add a 10 Ohm resistor
ps. sorry have no pics of said GTR resistor pack as ive never seen one and dont have one :P
  • 2 months later...
Does anyone know if you can run low impedence injectors in an rb20det silver top with a microtech lt12s ecu without doing the resister pack??
is there a function in the computer to set low or high impedence???
  • 1 month later...
Hey roy,
Thanks for the great tutorial. Helped heaps. Was a little confused when my resistor pack only measuered 6.7 ohms but checked it against a mates gtr pack running in his car and was the same. I can see why some people say that they have low impedance injectors without the ballast resistor. Throughout this topic it is stated that you need to make up the difference which is roughly 10 ohms. Not true..... The standard resistor pack out of a 32 gtr measures only 6.7 ohms so with the gtr injectors it only comes to roughly 9.3 ohms give or take. Elsewhere I've read that high impedance injectors run between 12 and 16 ohms which makes sense because my GTST injectors measured 14.4 ohms. I installed my resistor pack and gtr injectors two days ago then drove alll the way too sydney without a problem. Just wanted to put some figures out there so people know roughly what to expect. Any questions just PM me :(
Thanks again ROY, absolute legend for the tutorial :thumbsup:
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
