poobah Posted October 10, 2010 Share Posted October 10, 2010 i'm also in the middle of using the jaycar resistors in the loom..does anyone who has done this way know whether it makes a difference if i have the resistor on the positive or negative wire of the injector?? cheers. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5488730 Share on other sites More sharing options...
Rolls Posted October 10, 2010 Share Posted October 10, 2010 Shouldn't really matter but the resistor packs puts them all on the positive end. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5488776 Share on other sites More sharing options...
Rekin Posted October 10, 2010 Share Posted October 10, 2010 Cant remember if ive posted it in here before; This is the method I came up with for the GTR injector wiring. Much easier than the explained method in this thread! Pretty much, find the common 12v wire using a multimetre and wire directly off the plug. Saves the effort of stripping back all the wiring etc Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5489053 Share on other sites More sharing options...
Rolls Posted October 10, 2010 Share Posted October 10, 2010 Top post. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5489065 Share on other sites More sharing options...
poobah Posted October 10, 2010 Share Posted October 10, 2010 thanks rekin!!yeah thats a top diagram.. i'm not using the gtr ballast resistor just 6 individual resistors.. so pretty much just putting the resistors on the positive wire before each injector. or rolls, you think it shouldn't matter either on pos or neg.?could you explain? cheers! Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5489165 Share on other sites More sharing options...
Rolls Posted October 10, 2010 Share Posted October 10, 2010 (edited) What a resistor does is it causes a voltage drop and hence drops the current flowing through the circuit, as the current is the same for all elements in a loop (battery > injector driver > injector > resistor > battery ground) and the aim is to lower the current to stop the injector driver burning out it doesn't matter where in the circuit it is placed, it will have exactly the same effect. Edited October 10, 2010 by Rolls Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5489171 Share on other sites More sharing options...
poobah Posted October 11, 2010 Share Posted October 11, 2010 thanks so much!! this helps a lot! Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5489746 Share on other sites More sharing options...
poobah Posted October 11, 2010 Share Posted October 11, 2010 also. when fitting the actual injector.did people remove the O ring on the bottom of the gtr injector, so the fuel rail can screw in all the way (the gtr injectors seem real tight)? there already is a rubber seal in the head of the rb20, because the stock injectors dont have this O ring attached to the injector itself. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5490064 Share on other sites More sharing options...
HR31-PASSAGE Posted October 14, 2010 Share Posted October 14, 2010 ok i'm putting r32 gtr injectors into my rb25det & i've noticed the bigger/bottom O rings on the engine side (NOT the fuel rail side), the O ring hole is to large for the injector to sit in place! so what O rings should i use the rb20 or gtr O rings? cheers luke Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5497560 Share on other sites More sharing options...
Rolls Posted October 14, 2010 Share Posted October 14, 2010 (edited) You also need an aftermarket fuel rail as they are top fee, I got some custom spacers machined up personally for the bottom so they would fit. Edited October 14, 2010 by Rolls Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5497812 Share on other sites More sharing options...
HR31-PASSAGE Posted October 15, 2010 Share Posted October 15, 2010 You also need an aftermarket fuel rail as they are top fee, I got some custom spacers machined up personally for the bottom so they would fit. yeah thats already done. just trying to work out ow to get them to fit properly.... what did your spacers look like? can you pm me a pic by any chance? Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5498142 Share on other sites More sharing options...
Rolls Posted October 15, 2010 Share Posted October 15, 2010 Just round metal rings, you'll need to measure the size difference and get them made to fit. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5498198 Share on other sites More sharing options...
HR31-PASSAGE Posted October 16, 2010 Share Posted October 16, 2010 (edited) i have these injectors there 550cc & if there the same roundness to fit in the hole where the red circle is are they possible to use? heres a pic on the ones i have also... Edited October 16, 2010 by HR31-PASSAGE Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5500831 Share on other sites More sharing options...
HR31-PASSAGE Posted October 18, 2010 Share Posted October 18, 2010 anyone? Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5503765 Share on other sites More sharing options...
Rolls Posted October 18, 2010 Share Posted October 18, 2010 No idea, you'd have to compare measurements or trial fit them. What brand are they, can you find a datasheet for them? Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5504107 Share on other sites More sharing options...
bubba Posted May 21, 2011 Share Posted May 21, 2011 Home made resistor pack Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5824959 Share on other sites More sharing options...
Rolls Posted May 22, 2011 Share Posted May 22, 2011 what did you use to strap all the resistors together? Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5825833 Share on other sites More sharing options...
bubba Posted May 23, 2011 Share Posted May 23, 2011 It's some really fancy fabric electrical tape that my auto-eleccy mate gave me. I grouped them into 2 layers of 3 resistors, cut some ally to use as spacers/heatsinks. Ally spacers on the bottom, in between and on top of the resistors. Used thermal paste between it all and taped either end and longitudinally with the fabric tape (also acts as a damper to take up the minimal slack between the assembly and the case) then thermal pasted the exposed ally top and bottom so that the case can be used as a heat sink too. I was quite concerned with the assembly moving around and any exposed wires contacting the case (hello fire). The fat power feed to the resistors I stripped back quite far, split it into two and ran three resistors to each with all exposed wire heat shrunk all the way to the resistors. I have made a new loom just for the power feeds to the injectors, just need to extend the original injectors earths and then crimp the plugs on. My autoleccy mate sourced me some brand new Bosch plugs with seals and boots to suit the GTR injectors and let me borrow his terminal crimper Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5827556 Share on other sites More sharing options...
Rolls Posted May 23, 2011 Share Posted May 23, 2011 looks like a really neat job, well done. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5827885 Share on other sites More sharing options...
stÖrmy Posted June 25, 2011 Share Posted June 25, 2011 It's some really fancy fabric electrical tape that my auto-eleccy mate gave me. I grouped them into 2 layers of 3 resistors, cut some ally to use as spacers/heatsinks. Ally spacers on the bottom, in between and on top of the resistors. Used thermal paste between it all and taped either end and longitudinally with the fabric tape (also acts as a damper to take up the minimal slack between the assembly and the case) then thermal pasted the exposed ally top and bottom so that the case can be used as a heat sink too. I was quite concerned with the assembly moving around and any exposed wires contacting the case (hello fire). The fat power feed to the resistors I stripped back quite far, split it into two and ran three resistors to each with all exposed wire heat shrunk all the way to the resistors. I have made a new loom just for the power feeds to the injectors, just need to extend the original injectors earths and then crimp the plugs on. My autoleccy mate sourced me some brand new Bosch plugs with seals and boots to suit the GTR injectors and let me borrow his terminal crimper hey mate ive just acquired some 33gtr injectors to go into my rb20 what resisters did you use? as i want to make one as well. Link to comment https://www.sau.com.au/forums/topic/62674-gtr-injectors-into-rb20det/page/6/#findComment-5882641 Share on other sites More sharing options...
