hehehe:headspin: :D
haha i was talking 2 a friend who's in greece atm. & told him that i got sunburnt & this is the convo as follows:
gotta start saving 4 my 21st.!!! not much left hmm dealing with o/s parties is annoying says:
hey man
Tiger boy says:
hey
went on a cruise 2day sunburnt for the 1st time in ages
Tiger boy says:
to where?
wisemans ferry about 30 odd cars
Tiger boy says:
That's great!
i no but im burnt
Tiger boy says:
Here they put yoghurt in these cases!
haha
Tiger boy says:
I'm serious!
hehehehehehe
roflmfao
yoghurt on my left arm & face
hehehehehehehehehehehehehehehehehehehehehehehehehehehe
Tiger boy says:
Did u put?
no
im imagining it
Tiger boy says:
You should put a bit!
Tiger boy says:
Greek yoghurt preferrable!
pfft where would i get that
Tiger boy says:
Woolworths probably!
:):(:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
& how long would u leave it on
4?
Tiger boy says:
What's this yelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyelrotfyel
otfyelrotfyelrotf???
damn u cant c it
hmm
Tiger boy says:
for at least half an hour!
rofl smilie
Tiger boy says:
You will feel cool!
haha
does it work?
Tiger boy says:
Ofcourse it does!
Tiger boy says:
50 bucks bet, deal?
yeah u cough up either way
Tiger boy says:
Believe it or not, it works!
so half an hour- an hour?
Tiger boy says:
Put for 30' and see how u feel!Alright?
hmm..
i'll get laughed @
Tiger boy says:
Ur choice!
hmm if only u were her instead of in greece i'd do it @ ur place
Tiger boy says:
Ok, wait untill I come!
it mite b gone by then. hurry up. lol
hehe i'm gonna post this on an internet car forum. so the others who got burnt can read it. ne objections?
Tiger boy says:
ok
can i?
Tiger boy says:
What?
post it
this yogurt business
Tiger boy says:
ok!
Tiger boy says:
no problem!
posted it
this convo
Tiger boy says:
"Attiki"
say what
Tiger boy says:
is the name of this yogurt!
ne takers?
https://www.sau.com.au/forums/topic/62675-for-those-sunburntincluding-me/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
