driver training day (drift)oran park Sunday Feb 27th
FDD returns oran park south circuit SUN 27th feb
same as all the other time 20 spots for drift and 40 for the track
all welcome
Circuit and Drift day all welcome 27th Feb 2005
Driver training: Aaron McGill of Auto-Motion Australia will have professional driver trainers on hand to give tips on circuit and drift techniques. The focus of the day is to improve driving techniques for drivers of all skill levels and have a great time. Flag marshal posts will be manned on the day.
Where: Oran Park South Circuit Time: Get to the track at 8am for sign on and scrutineering. The day will finish at 5pm. There will be three rotating sessions of 20 minutes through out the day one for circuit training and one for drifting.
Cost: $150 (for the full day and includes lunch) discounts apply for club members.Limited numbers: There will only be 60 spots available for the day. Get in quick! Three sessions of 20 minutes (one drift session and 2 track sessions)
Drivers will need: Helmet, long sleeve shirt and long pants. Cars will be inspected to check for track worthiness.
Spectators: $5.00 will be charged to all spectators. Viewing area to be advised.
Bookings: Payment will need to be finalised by 20 Feb 2004. Email Peter on [email protected] for payment details
Whether you drive a stock family car or the latest Jap drifting machine, get out there and give it a go. Where else do you get to drive fast, safe & sideways, and where it's legal?
The day is organised by Peter Carruthers, and professionally run by Aaron McGill of Auto-Motion Australia driver training - Aaron McGill has 20 years racing experience and 11 years professional driving instructing experience. Oran Park Raceway - Cobbitty Road, NARELLAN For any enquiries, call Peter on 0409 226 626.
  • Replies 145
Just to clarify - Is that only 60 minutes of track time for the whole day? And it must be 1 session drift, 2 track? I.E. Can you do 3 of track, or 3 of drift, or 2 drift, 1 track....
I doubt I will have my car by then, But I could be interested in the next one.
You are put in one of the three groups (drift, track1 or track2).
Each session is 20 minutes. After 20 minutes you all go back in and the next group goes out.
The last one i think we all did 5 or 6 sessions at least?? The day is from 9-5. There is a small break for lunch which was filled with a passenger drift session. And at the start of the day is a driver briefing..
cool. sounds good
So south circuit....is that the one they have the drift comps on (the one under the bridge) or is it the main faster circuit, where they cut of the cool corners around the bridge?
If it is the main circuit, how does drifitng go there? I havn't paid a huge amount of attention, but i', guessing u'd need to be doing some bloody fast drift to drift thos corners?
grab'd my interest.. but one thing i need to know is, and i've posted this up once b4. Can u drift using an auto/tipronic g/box?.. i'm interested in doin` the track but more liking to drift. If so would there be someone there to show me how to do so with the auto?.. Oh and another thing.. the car lags! Hits boost bout 4000rpm, is that a problem?
thanks
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
